Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
- To:
- Subject: Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
- Date: Mon, 30 Nov 2015 08:13:54 -0800 (PST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:XPMr7RzxOLTA/JfXCy+O+j09IxM/srCxBDY+r6Qd0e4TIJqq85mqBkHD//Il1AaPBtWGraIUwLCH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU35T8jbH60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs2obVGoNkhdODFmZpEXmV5HgtS31repw3ibCbZWrZb8xUDWmqaxsTUm72288Kzcl/TSP2YRLh6VBrUf5qg==
Hi, thanks for your reply. I still confusing about what you are talking
about. I have successfully configure libQGLViewer which it generated a dylib
and framework by compiling libQGLViewer in Qt 5.5. And on cmake, i just put
the path on the given libQGLViewer variable for lib and framework. Can you
provide more detail?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fail-to-run-Polyhedron-demo-with-reason-Image-not-found-tp4661416p4661423.html
- [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', Sebastien Loriot (GeometryFactory), 11/30/2015
