cgal-discuss - Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
  • To:
  • Subject: Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
  • Date: Mon, 30 Nov 2015 08:32:33 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:DtwosR+EJM1B9/9uRHKM819IXTAuvvDOBiVQ1KB91+8cTK2v8tzYMVDF4r011RmSDdidu6IP0LGempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lR8iC34/sjKibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MFJVeD2fr8zUKdDJDUgKWE8osPx5jfZSg7a93waXX4WnxxHUlSNuA3zWIb2tCThtud713HKZZDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
I go into 'QGLViewer.framework/Versions/2/QGLViewer' and run QGLViewer unix
executable but fail. It says '*-bash:
/usr/local/lib/QGLViewer.framework/Versions/2/QGLViewer: cannot execute
binary file*'. Is this the problem that causes QGLViewer library cannot be
loaded?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fail-to-run-Polyhedron-demo-with-reason-Image-not-found-tp4661416p4661424.html
