Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
- To:
- Subject: Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found'
- Date: Mon, 30 Nov 2015 13:36:25 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:e1wBLhI/xF7+x/LuUdmcpTZWNBhigK39O0sv0rFitYgULPjxwZ3uMQTl6Ol3ixeRBMOAu68C27Wd7/uocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLniKvuoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JGF4bmBNTHwnI6lneWY3wtTey9sVw3yyXIdfnY7k/RTO4/uYhAEvzjCAdNjkltmTTosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
On 11/30/2015 12:30 PM, yongsheng94 wrote:
Can you provide some guides?
I probably just following these steps:
Step 1: cmake-gui .
Step 2: make
Step 3: run executable
libqglviewer is not using cmake but qmake IIRC. So I guess you're
talking about how to compile CGAL while it's about compiling
libqglviewer with qt5 (which is equivalent to run the qmake of
qt5 to configure libqglviewer).
More details here:
http://libqglviewer.com/installUnix.html#mac
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Fail-to-run-Polyhedron-demo-with-reason-Image-not-found-tp4661416p4661421.html
- [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', yongsheng94, 11/30/2015
- Re: [cgal-discuss] Fail to run 'Polyhedron' demo with reason: 'Image not found', Sebastien Loriot (GeometryFactory), 11/30/2015
