- To:
- Subject: [cgal-discuss] Arrangement to file not working
- Date: Fri, 4 Dec 2015 00:40:11 -0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:L43YsBN9497iIZK2y/cl6mtUPXoX/o7sNwtQ0KIMzox0KP/yrarrMEGX3/hxlliBBdydsKIazbKO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStCU15z//tvx0qOQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9YwuxhX7vku/soFXaThdLkjVpRZCi4nOiY7/p7Frx7GGC6G+nYBSS08nx5MBA3CpEX/V4v8rzDwu+553yydFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Hello
I'm trying to use the I/O functions to write and read an arrangement to a file. The problem is that when I try to read the arrangement from the file the program get stucked. I'm using a very simple program to test and I already checked the file generated by write and it is not empty. My .cpp code:Arrangement_2 arr1,arr2;
Point_2 p1 (1 , 3 ) , p2 (3 , 5 ) ;
XSegment_2 s1 (p1 , p2 ) ;
Arrangement_2::Halfedge_handle e1 = arr1.insert_in_face_interior( s1 ,arr1.unbounded_face( ) ) ;
Vertex_handle v1 = e1->source();
ofstream out_file("arr_ex_io.dat");
out_file << arr1;
out_file.close();
ifstream in_file("arr_ex_io.dat");
in_file >> arr2;
in_file.close();
- [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Sebastien Loriot (GeometryFactory), 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Efi Fogel, 12/05/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/05/2015
