- To:
- Subject: Re: [cgal-discuss] Arrangement to file not working
- Date: Sat, 5 Dec 2015 11:39:30 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:pN1neRC7fkkxtFz1ShItUyQJP3N1i/DPJgcQr6AfoPdwSP7zpcbcNUDSrc9gkEXOFd2CrakU1ayO6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6MyZzvn8mJuLTtICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0roGxtvek8/ZtATbniZPZ/CqdJCSwvdWEz/szi8xfZChCe42MVFWQQnB0PCAfM6FT2X4z6rzDh5dZ6jSKVNMmzQbEvUim59I9qTgXpgWEJLW0X6mbS3+F+jep1px2so1QrzoDVboaaOf5WcabUfNdcTm1ECJUCHxddC5+xOtNcR9EKOvxV+tHw
Hi Mateus,
You have encountered a bug (or perhaps two) in the exporter and importer of polycurves.The next release of CGAL will include the fix.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Fri, Dec 4, 2015 at 2:37 PM, Mateus Bellomo <> wrote:
Thank youI'm not sure about that: the kernel is the CGAL::Cartesian<Number_type> ?I'm sending the .cpp and CMakeLists attached.2015-12-04 5:33 GMT-02:00 Sebastien Loriot (GeometryFactory) <>:What kernel are you using?
Please provide a complete example we can compile and run.
Sebastien.--
On 12/04/2015 03:40 AM, Mateus Bellomo wrote:
Hello
I'm trying to use the I/O functions to write and read an arrangement to
a file. The problem is that when I try to read the arrangement from the
file the program get stucked. I'm using a very simple program to test
and I already checked the file generated by write and it is not empty.
My .cpp code:
Arrangement_2 arr1,arr2;
Point_2 p1 (1 , 3 ) , p2 (3 , 5 ) ;
XSegment_2 s1 (p1 , p2 ) ;
Arrangement_2::Halfedge_handle e1 = arr1.insert_in_face_interior( s1
,arr1.unbounded_face( ) ) ;
Vertex_handle v1 = e1->source();
ofstream out_file("arr_ex_io.dat");
out_file << arr1;
out_file.close();
ifstream in_file("arr_ex_io.dat");
in_file >> arr2;
in_file.close();
Anyone had the same problem? Thanks in advance
diff --git a/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Polycurve_2.h b/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Polycurve_2.h index fb4cf5f..28774dd 100644 --- a/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Polycurve_2.h +++ b/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Polycurve_2.h @@ -441,22 +441,16 @@ template <typename SubcurveType_2, typename PointType_2> std::ostream& operator<<(std::ostream & os, const Polycurve_2<SubcurveType_2, PointType_2>& cv) { - typedef SubcurveType_2 Subcurve_type_2; - typedef PointType_2 Point_type_2; + typedef SubcurveType_2 Subcurve_type_2; + typedef PointType_2 Point_type_2; + typedef Polycurve_2<Subcurve_type_2, Point_type_2> Curve_2; - typedef Polycurve_2<Subcurve_type_2, Point_type_2> Curve_2; + // Export the number of subcurves. + os << cv.number_of_subcurves(); + // Export the subcurves. typename Curve_2::Subcurve_const_iterator iter = cv.begin_subcurves(); - while (iter != cv.end_subcurves()) { - if (iter == cv.begin_subcurves()) { - os << " " << *iter; - ++iter; - } - else { - os << " <-> " << *iter; - ++iter; - } - } + while (iter != cv.end_subcurves()) os << " " << *iter++; return (os); } @@ -467,30 +461,18 @@ std::istream& operator>>(std::istream& is, { typedef SubcurveType_2 Subcurve_type_2; typedef PointType_2 Point_type_2; - typedef Polycurve_2<Subcurve_type_2, Point_type_2> Curve_2; - // Read the number of input points. - unsigned int n_pts; - is >> n_pts; - CGAL_precondition_msg(n_pts > 1, "Input must contain at least two points"); - - // Read m_num_pts points to a list. - Point_type_2 p; - std::list<Point_type_2> pts; - for (unsigned int i = 0; i < n_pts; ++i) { - is >> p; - pts.push_back(p); - } + // Import the number of curves. + size_t num; + is >> num; + // Import the subcurves. std::list<Subcurve_type_2> subcurves; - typename std::list<Point_type_2>::iterator curr = pts.begin(); - typename std::list<Point_type_2>::iterator next = pts.begin(); - ++next; - while (next != pts.end()) { - subcurves.push_back(Subcurve_type_2(*curr, *next)); - ++curr; - ++next; + for (size_t i = 0; i < num; ++i) { + Subcurve_type_2 subcurve; + is >> subcurve; + subcurves.push_back(subcurve); } // Create the polycurve curve.
- [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Sebastien Loriot (GeometryFactory), 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Efi Fogel, 12/05/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/05/2015
