- To:
- Subject: Re: [cgal-discuss] Arrangement to file not working
- Date: Fri, 4 Dec 2015 10:37:49 -0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:2KRWZxXnoaFwaSLQZRclbcoUH9LV8LGtZVwlr6E/grcLSJyIuqrYZh2Ft8tkgFKBZ4jH8fUM07OQ6PC+HzRYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770o8WbSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/NGSrjwKqQkUaRDXnNhKHEw/MSttB/ZTALJ6GFbSXQTihMPAg7L61bxUZ719yf7reFgwzLJAcqjRr89XXGu7rxgVQTzoCYBLT8wtm/N2eJqi6cOhRu9qgFki6TZZIWSMf02KqbUYd4HXmBMWsJWUitpDYa1bo9JBO0Ea7UL57LhrkcD+EPtTTKnA/nin2dF
I'm not sure about that: the kernel is the CGAL::Cartesian<Number_type> ?
I'm sending the .cpp and CMakeLists attached.2015-12-04 5:33 GMT-02:00 Sebastien Loriot (GeometryFactory) <>:
What kernel are you using?
Please provide a complete example we can compile and run.
Sebastien.--
On 12/04/2015 03:40 AM, Mateus Bellomo wrote:
Hello
I'm trying to use the I/O functions to write and read an arrangement to
a file. The problem is that when I try to read the arrangement from the
file the program get stucked. I'm using a very simple program to test
and I already checked the file generated by write and it is not empty.
My .cpp code:
Arrangement_2 arr1,arr2;
Point_2 p1 (1 , 3 ) , p2 (3 , 5 ) ;
XSegment_2 s1 (p1 , p2 ) ;
Arrangement_2::Halfedge_handle e1 = arr1.insert_in_face_interior( s1
,arr1.unbounded_face( ) ) ;
Vertex_handle v1 = e1->source();
ofstream out_file("arr_ex_io.dat");
out_file << arr1;
out_file.close();
ifstream in_file("arr_ex_io.dat");
in_file >> arr2;
in_file.close();
Anyone had the same problem? Thanks in advance
# This is the CMake script for compiling a set of CGAL applications.
project( a.out )
cmake_minimum_required(VERSION 2.6.2)
if("${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}" VERSION_GREATER 2.6)
if("${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}"
VERSION_GREATER 2.8.3)
cmake_policy(VERSION 2.8.4)
else()
cmake_policy(VERSION 2.6)
endif()
endif()
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11 -g ")
set( CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true )
if ( COMMAND cmake_policy )
cmake_policy( SET CMP0003 NEW )
endif()
# CGAL and its components
find_package( CGAL QUIET COMPONENTS )
if ( NOT CGAL_FOUND )
message(STATUS "This project requires the CGAL library, and will not be
compiled.")
return()
endif()
# include helper file
include( ${CGAL_USE_FILE} )
# Boost and its components
find_package( Boost REQUIRED )
if ( NOT Boost_FOUND )
message(STATUS "This project requires the Boost library, and will not be
compiled.")
return()
endif()
# include for local directory
# include for local package
# Creating entries for target: a.out
add_executable( a.out generateRandom.cpp )
add_to_cached_list( CGAL_EXECUTABLE_TARGETS a.out )
# Link the executable to CGAL and third-party libraries
target_link_libraries(a.out ${CGAL_LIBRARIES} ${CGAL_3RD_PARTY_LIBRARIES} )
#include <CGAL/Cartesian.h> #include <CGAL/Quotient.h> #include <CGAL/MP_Float.h> #include <CGAL/Arr_segment_traits_2.h> #include <CGAL/Arr_polyline_traits_2.h> #include <CGAL/Arrangement_2.h> #include <CGAL/Arr_extended_dcel.h> #include <bits/stdc++.h> #include <CGAL/basic.h> #include <CGAL/IO/Arr_iostream.h> #include "arr_print.h" #define EPS 1e-3 #define pb push_back using namespace std; typedef CGAL::Quotient<CGAL::MP_Float> Number_type; typedef CGAL::Cartesian<Number_type> Kernel; typedef CGAL::Arr_segment_traits_2<Kernel> Segment_traits_2; typedef CGAL::Arr_polyline_traits_2<Segment_traits_2> Traits_2; typedef Traits_2::Point_2 Point_2; typedef Traits_2::Curve_2 Polyline_2; typedef CGAL::Arrangement_2<Traits_2> Arrangement_2; typedef Segment_traits_2::X_monotone_curve_2 XSegment_2; typedef Arrangement_2::Vertex_handle Vertexh; Arrangement_2 arr; int main (){ Arrangement_2 arr1,arr2; Point_2 p1 (1,3), p2(2,4); XSegment_2 s1 (p1,p2); Arrangement_2::Halfedge_handle e1 = arr1.insert_in_face_interior( s1 , arr1.unbounded_face( ) ) ; Vertexh v1 = e1->source(); ofstream out_file("arr_ex_io.dat"); out_file << arr1; out_file.close(); ifstream in_file("arr_ex_io.dat"); if(in_file.is_open()){ cout << "open" << endl; in_file >> arr2; in_file.close(); } else{ cout << "not open" << endl; } return 0; }
- [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Sebastien Loriot (GeometryFactory), 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Efi Fogel, 12/05/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/05/2015
