- To:
- Subject: Re: [cgal-discuss] Arrangement to file not working
- Date: Fri, 04 Dec 2015 08:33:31 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:v+evHBzR9PQbqDTXCy+O+j09IxM/srCxBDY+r6Qd0e8eIJqq85mqBkHD//Il1AaPBtWFraocw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwudrqzQtaapv/0/t7x0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKJkpi9fsvZk+89bWrjhZIw5S6ZZBXIoKTMb/sru4FP4QAGG/WcdX2Neth1SAg/ZpFHVU5D0vzfgp8R00zWdJ9y3B/hgQjCl9aZsVFntjA8IMjc49Cfcjckm3/ETmw6ouxEqm92cW4qSLvcrJq4=
What kernel are you using?
Please provide a complete example we can compile and run.
Sebastien.
On 12/04/2015 03:40 AM, Mateus Bellomo wrote:
Hello
I'm trying to use the I/O functions to write and read an arrangement to
a file. The problem is that when I try to read the arrangement from the
file the program get stucked. I'm using a very simple program to test
and I already checked the file generated by write and it is not empty.
My .cpp code:
Arrangement_2 arr1,arr2;
Point_2 p1 (1 , 3 ) , p2 (3 , 5 ) ;
XSegment_2 s1 (p1 , p2 ) ;
Arrangement_2::Halfedge_handle e1 = arr1.insert_in_face_interior( s1
,arr1.unbounded_face( ) ) ;
Vertex_handle v1 = e1->source();
ofstream out_file("arr_ex_io.dat");
out_file << arr1;
out_file.close();
ifstream in_file("arr_ex_io.dat");
in_file >> arr2;
in_file.close();
Anyone had the same problem? Thanks in advance
- [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Sebastien Loriot (GeometryFactory), 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/04/2015
- Re: [cgal-discuss] Arrangement to file not working, Efi Fogel, 12/05/2015
- Re: [cgal-discuss] Arrangement to file not working, Mateus Bellomo, 12/05/2015
