cgal-discuss - Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
  • To:
  • Subject: Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
  • Date: Thu, 28 Jan 2016 02:56:22 -0800 (PST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:1zdyMhyte8Uz9L7XCy+O+j09IxM/srCxBDY+r6Qd0e4VIJqq85mqBkHD//Il1AaPBtWEraoYwLCO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU15j8jbj60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs3AcU38flBhJCRPY9lmuRYrr9CD6t/B03iubN+X5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
Hi,
I am very new to CGAL and I am learning/using this for the first time. I
faced similar problems and found this thread. However, I have a questions:
What do you mean by adding "#define CGAL_EIGEN3_ENABLED worked fine".
Where you add this line too ?
There are many examples which gives similar compilation error. Is there any
global setting that I can modify so that the compilation goes smoothly?
Thanks in advance.
Chiranjib
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compile-error-In-Surface-mesh-deformation-h-tp4660587p4661527.html
