cgal-discuss - Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
  • To:
  • Subject: Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
  • Date: Thu, 28 Jan 2016 12:23:19 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:dQH0mB+x9Tz2Ov9uRHKM819IXTAuvvDOBiVQ1KB91u4cTK2v8tzYMVDF4r011RmSDdqds64P0bKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRciK04/tj6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MFJVeD2fr8zUKdDJDUgKWE8osPx5jfZSg7az30QSGgfiVJmCgLf7VmuV5H9qCbzraxz0SOAPOX5QLcxVCi4/qliQwPvkjZBPDk8pjKEwvdshb5W9Ury7yd0xJTZNdmY
When you configure an example using cmake you have to give it
the directory of Eigen which you must have download separately.
andreas
On 28/01/2016 11:56, chiranjibsur wrote:
Hi,
I am very new to CGAL and I am learning/using this for the first time. I
faced similar problems and found this thread. However, I have a questions:
What do you mean by adding "#define CGAL_EIGEN3_ENABLED worked fine".
Where you add this line too ?
There are many examples which gives similar compilation error. Is there any
global setting that I can modify so that the compilation goes smoothly?
Thanks in advance.
Chiranjib
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compile-error-In-Surface-mesh-deformation-h-tp4660587p4661527.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
