- To:
- Subject: Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
- Date: Thu, 28 Jan 2016 16:58:41 +0530
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:H/BphBy7YK2+BBDXCy+O+j09IxM/srCxBDY+r6Qd0eMRIJqq85mqBkHD//Il1AaPBtWEraoYwLCJ+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU15j8jb/60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD888n7NNKBKXmY7wjH/sfFyUjK2lz5cvxtBCFQxHI/WoZSmxRkxxGBE/O4xj+G5vwqSDnrfEu5C7PNsL/SfU4WC+p8rxwYB7ukiYOcTAjo0/Njcklp6JauhunpR11i7XJesnBL+dkOKjdfMkTQ2hAVO5eUiVABsW3aI5ZXLlJBvpRs4So/whGlhC5HwT5XO4=
Hi Andreas,
Thank you very much for the message. Just to know more here are the things I am doing :
1. Trying to compile the example Surface_modeling (cgal 4.5)
2. Steps i followed :
a) create the CMakeLists.txt by using the script "cgal_create_CMakeLIsts
b) run cmake to generate make file
c) run make to compile
Things are ok upto generating makefile but when I run make, I get the compilation error.
As you suggested, what do you mean "when you configure cmake" ? Do you mind sending few more information about the steps one needs to follow to compile this example ?
Thanks again,
CHiranjib
On Thu, Jan 28, 2016 at 4:53 PM, Andreas Fabri <> wrote:
When you configure an example using cmake you have to give it
the directory of Eigen which you must have download separately.
andreas
On 28/01/2016 11:56, chiranjibsur wrote:
Hi,
I am very new to CGAL and I am learning/using this for the first time. I
faced similar problems and found this thread. However, I have a questions:
What do you mean by adding "#define CGAL_EIGEN3_ENABLED worked fine".
Where you add this line too ?
There are many examples which gives similar compilation error. Is there any
global setting that I can modify so that the compilation goes smoothly?
Thanks in advance.
Chiranjib
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Compile-error-In-Surface-mesh-deformation-h-tp4660587p4661527.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, chiranjibsur, 01/28/2016
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, Andreas Fabri, 01/28/2016
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, Chiranjib Sur, 01/28/2016
