- To:
- Subject: Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h
- Date: Thu, 28 Jan 2016 12:32:39 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:RD1W+hdnDZqoxz3+FIaEK7BxlGMj4u6mDksu8pMizoh2WeGdxc+6Yx7h7PlgxGXEQZ/co6odzbGG7Oa4BSdavt6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcWPKF8XzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3Heb8lR+lYECg+KDJyo9b6sAHKCwqJ/HoVFGsM1QFZBhDMqxD8UJC2uSTzsq9x2TKRINbtHowzDD+t5qMuRB7zgzocLBY49nvWg4p+lvF1uhWk8jV5z5TZaZrdGvN0ZKKVKdocSXBMV90XWSVLGIKUYIYICucdJ/dWpoLhoEEf6xC5AF//V6vU1jZUiyqujuUB2OM7HFSe0Q==
On 28/01/2016 12:28, Chiranjib Sur wrote:
Hi Andreas,
Thank you very much for the message. Just to know more here are the
things I am doing :
1. Trying to compile the example Surface_modeling (cgal 4.5)
2. Steps i followed :
a) create the CMakeLists.txt by using the script "cgal_create_CMakeLIsts
Isn't there already a CMakeLists.txt ??
You overwrite it when you run the script
And in the one overwritten was a find (Eigen)
andreas
b) run cmake to generate make file
c) run make to compile
Things are ok upto generating makefile but when I run make, I get the
compilation error.
As you suggested, what do you mean "when you configure cmake" ? Do you
mind sending few more information about the steps one needs to follow to
compile this example ?
Thanks again,
CHiranjib
On Thu, Jan 28, 2016 at 4:53 PM, Andreas Fabri
<mailto:>>
wrote:
When you configure an example using cmake you have to give it
the directory of Eigen which you must have download separately.
andreas
On 28/01/2016 11:56, chiranjibsur wrote:
Hi,
I am very new to CGAL and I am learning/using this for the first
time. I
faced similar problems and found this thread. However, I have a
questions:
What do you mean by adding "#define CGAL_EIGEN3_ENABLED worked
fine".
Where you add this line too ?
There are many examples which gives similar compilation error.
Is there any
global setting that I can modify so that the compilation goes
smoothly?
Thanks in advance.
Chiranjib
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compile-error-In-Surface-mesh-deformation-h-tp4660587p4661527.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 <tel:%2B33.492.954.912> skype: andreas.fabri
Andreas Fabri, PhD
phone: +33.492.954.912 skype: andreas.fabri
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, chiranjibsur, 01/28/2016
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, Andreas Fabri, 01/28/2016
- Re: [cgal-discuss] Compile error: In Surface_mesh_deformation.h, Chiranjib Sur, 01/28/2016
