- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Thu, 25 Feb 2016 08:32:38 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:JIteYBNmWxhbrYmX/vcl6mtUPXoX/o7sNwtQ0KIMzox0KPn9rarrMEGX3/hxlliBBdydsKIbzbeH+Pm4BiQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb3jsMSLPE1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDuxxEGQXM91nUV53rs2Ouv+xxwiSTJov4RLouWByt4qBuRQPymSkOPCI+6nCRgct12vEI6Cm9rgByltaHKLqeM+BzK/vQ
Have a look at the demo of the chapter
http://doc.cgal.org/4.8/Manual/packages.html#PkgBoundingVolumesSummary
It visualizes min circle and min ellipse.
andreas
On 25/02/2016 06:57, tcscott wrote:
Dear All
Thanks for the feedback and clarification so far.
I am trying other examples in CGAL. I tried Min_circle_2
I would get an executible a.out from:
g++ -L/opt/local/lib -lcgal -I/opt/local/include/ -lgmp -lmpfr
-L/opt/local/lib/ -lboost_thread-mt min_circle_2.cpp
Output:
CGAL::Min_circle_2( |P| = 100, |S| = 2
P = {
PointC2(98, 0),
PointC2(-99, 0),
PointC2(94, 0),
PointC2(92, 0),
PointC2(90, 0),
PointC2(-89, 0),
PointC2(64, 0),
PointC2(-85, 0),
PointC2(80, 0),
PointC2(96, 0),
PointC2(24, 0),
PointC2(-83, 0),
PointC2(-73, 0),
S = {
PointC2(98, 0),
PointC2(-99, 0),
circle = CGAL::Optimisation_circle_2( PointC2(-0.5, 0), 9702.25)
I would get a similar result from Min_ellipse_2
Question is: how to visualize the results?
My earlier and very first result with Convex_Hull could be done in
gnuplot because the output were x-y pairs but these are CGAL data
structures.
I found mention of the Qt Graphics View Framework:
http://doc.cgal.org/Manual/3.4/doc_html/cgal_manual/GraphicsView/Chapter_main.html
but I need a concrete example.
If I need additional software, what do I need to install?
What is the simplest way to visualize these results?
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/29/2016
