- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Fri, 26 Feb 2016 00:44:40 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:ezZUoxDLu9AD7uXk3EwmUyQJP3N1i/DPJgcQr6AfoPdwSP74o8bcNUDSrc9gkEXOFd2CrakU1KyI6eu5ADJIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbsodaKOlsArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITxwZDGAPC8A2yCov6qSD9qvZV1yyTPMmwRrcxD2fxp5x3QQPl3X9UfwUy93va35R9
Dear Andreas
Thank you. If you insist, yes I do:
cgal_create_CMakeLists -s executable
cmake -DCGAL_DIR=$HOME/CGAL-4.7 .
make
The last command yields:
Scanning dependencies of target executable
[ 50%] Building CXX object CMakeFiles/executable.dir/Bounding_volumes.cpp.o
/Users/tonyscott/Documents/CGAL/CGAL-4.7/demo/Bounding_volumes/Bounding_volumes.cpp:18:10:
fatal error:
'QtGui' file not found
#include <QtGui>
1 error generated.
make[2]: *** [CMakeFiles/executable.dir/Bounding_volumes.cpp.o] Error 1
make[1]: *** [CMakeFiles/executable.dir/all] Error 2
make: *** [all] Error 2
Bottom line is that file QtGui.h is missing.
Question: does Bounding_volumes work for you? and do you use/have a QtGui.h
at your end?
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661637.html
- [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/29/2016
