- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Fri, 26 Feb 2016 09:36:16 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:pqIG6xLwkt7XH2CjztmcpTZWNBhigK39O0sv0rFitYgUL/rxwZ3uMQTl6Ol3ixeRBMOAu60C1bCd6vm+EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35vxibr5osSNKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzA/lBZSDgHepD/zVI3w+n/zsOZn1SCBe8P/R6o1cTuv6KJmVAX5hi4MKzkj4Sfcjckm3/ETmw6ouxEqm92cW4qSLvcrJq4=
Hi Scott,
It makes no sense to stipple together a g++ -L ....
The CGAL library, as well as the examples and demo come
with CMakeLists.txt files for cmake, you have to configure
and generate a Makefile (or whatever generator you choose)
and then call make, and then you have your demo.
Note also that what I write here informally,
is documented.
Best,
Andreas
On 26/02/2016 08:29, tcscott wrote:
Hi again
Still no visualization.
I did get to CGAL-4.7/demo/Bounding_volumes
and attempted to compile and link:
g++ -L/opt/local/lib -lcgal -I/opt/local/include/ -lgmp
Bounding_volumes.cpp
Bounding_volumes.cpp:18:10: fatal error: 'QtGui' file not found
#include <QtGui>
I downloaded Qt on my MAC (much to my chagrin because it took a long time).
It is a huge amount of code and I have still no idea what it does.
I did not find any QtGui.h though I did find a number of subdirectories
called QtGui. I tried:
-I/opt/local/libexec/qt5/include -lgmp Bounding_volumes.cpp
#include <QtGui>
Still no result. I cannot find QtGui.h anywhere.
Nor could I not find any solution on the web nor in past postings.
Has the QtGui.h been replaced by qwidget.h by any chance?
I could use some help :-(
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661635.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/29/2016
