- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Mon, 29 Feb 2016 02:58:31 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:qzPSNhyTyrpmW2PXCy+O+j09IxM/srCxBDY+r6Qd0ekUIJqq85mqBkHD//Il1AaPBtWErawUwLCO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU0ZT8jbj60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs2cXSW4RjgYAVxTO9xr9QovZvS7zt+470y6fa56lBYsoUCivuv84ACTjjz0KYmY0
Apparently in the transition from Qt4 to Qt5, there have been changes:
https://forum.qt.io/topic/22596/from-qt4-to-qt5-include-files-not-found
Files that used to be in Qt4 cannot be found in Qt5. That includes:
#include <QtGui>
#include <QString>
Professed Solution:
Add this in your *.pro file:
QT += widgets
Change all instances of
#include <QtGui>
to
#include <QtWidgets>
Trouble is I don't know where or what this .pro file is. I only found one
such file i.e.
example.pro in
~/Qt/Examples/Qt-5.5/
I cannot believe this because that also means substantial changes everywhere
else
for the demos (?)
Has anybody hit this problem? and does anybody have an economic solution?
Is anybody out there using Qt5 with CGAL-4.7 on a MAC?
best wishes and thanks in advance for any help.
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661653.html
- [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/25/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/26/2016
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 02/29/2016
- Re: [cgal-discuss] visualizing CGAL objects, Andreas Fabri, 02/29/2016
