cgal-discuss - Re: [cgal-discuss] visualizing CGAL objects
  • To:
  • Subject: Re: [cgal-discuss] visualizing CGAL objects
  • Date: Tue, 1 Mar 2016 22:04:40 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:989EpxJyz7qOiQ9ZktmcpTZWNBhigK39O0sv0rFitYgUKf7xwZ3uMQTl6Ol3ixeRBMOAu60C1LOd4v+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILojqvjpNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JTm4NmR1UH0CR8BrhVZDtrgP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
Dear all
THX. at least we're getting closer to the problem.
Simply put I don't have libCGAL_Qt5
I did install Qt5 for the MAC
I have done:
sudo port install cgal +qt5 +universal +demos
cmake -gui .
yields
libCGAL_ImageIO is configured
-- Sources for CGAL component library 'CGAL_Qt3' detected
-- Sources for CGAL component library 'CGAL_Qt5' detected
Configuring libCGAL_Qt5
-- libCGAL_Qt5 is missing the dependencies: Qt5Svg Qt5 cannot be
configured.
-- Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt5' detected
So it can sense the CGAL_Qt5.
I think the problem is listed in the CHANGES file:
To
compile libCGAL_Qt5 and demos, you must set the cmake or environment
variable Qt5_DIR to point to the path to the directory containing the
file
Qt5Config.cmake created by your Qt5 installation. If you are using the
open
source edition it should be /path-to/qt-everywhere-opensource-src-
<version>/qtbase/lib/cmake/Qt5.
So apparently libCGAL_Qt5 has to be compiled i.e. built and this was not
clearly
specified in the doc.
Moreover, I don't how to do it. Oh I can find Qt5Config.cmake and it is
correctly
listed in CMakeCache.txt. I just have no idea how to build libCGAL_Qt5
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661659.html
