- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Wed, 02 Mar 2016 16:21:11 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:fYgPahD/ASZ7piW/IOoMUyQJP3N1i/DPJgcQr6AfoPdwSP79o8bcNUDSrc9gkEXOFd2CrakU1KyJ6eu/ACQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokb/osMKKKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzBcqRdCChPZ7Rz8FrP2qCr9qqI99ySdOMDqV6EaUD++6L16CVWg3DwDMCQ4932Rj8hYg6dSoRbnrBt6ld2HKLqJPeZzK/uONegRQnBMC55c
As I already said the CGAL project is not responsible for
the creation of the macport package.
If you have installed all required dependencies, compiling CGAL is
simple:
> wget https://github.com/CGAL/cgal/releases/download/releases%2FCGAL-4.8-beta1/CGAL-4.8-beta1.zip
> unzip CGAL-4.8-beta1.zip
> cd CGAL-4.8-beta1
> cmake .
> make
> CGAL_DIR=`pwd`
> export CGAL_DIR
> cd demo/Triangulation_2
> cmake .
> make
Sebastien.
On 03/02/2016 03:41 PM, tcscott wrote:
Hello again
THX. At least this tells me what my problem is but I submit this is wholly
unacceptable for any new
user with a MAC. It means I cannot work out the demos nor visualize the
CGAL data structures on a MAC.
I have to think if I should even bother continuing with CGAL.
So much code.
So much effort.
but clearly the MAC version for this code is something of a bust.
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661662.html
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Sebastien Loriot (GeometryFactory), 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Daniel Duque, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Phil Weir, 03/03/2016
- Re: [cgal-discuss] visualizing CGAL objects, Adam Getchell, 03/03/2016
