- To:
- Subject: Re: [cgal-discuss] visualizing CGAL objects
- Date: Wed, 02 Mar 2016 15:58:17 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:FBrPDxJGTeZ51hiKFNmcpTZWNBhigK39O0sv0rFitYgULPjxwZ3uMQTl6Ol3ixeRBMOAu60C1LCd7f2ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILojavsptX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JGF4bmBNTHwnI6lneWY3wtTey9sVw3yyXIdfnY7k/RTO4/uYhAEvzjCAdNjkltmTTosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
Looking at the macport repo, it looks like the maintainer have
disabled CGAL_Qt5:
"bump to 4.7 and move to github port. Qt5 disabled because I can’t build it on my computer. To be enabled later."
https://trac.macports.org/browser/trunk/dports/gis/cgal/Portfile
You should probably build CGAL yourself (even if looking at the script
adding +qt5 should do the job, but I don't know anything about port
scripts).
Sebastien.
On 03/02/2016 07:04 AM, tcscott wrote:
Dear all
THX. at least we're getting closer to the problem.
Simply put I don't have libCGAL_Qt5
I did install Qt5 for the MAC
I have done:
sudo port install cgal +qt5 +universal +demos
cmake -gui .
yields
libCGAL_ImageIO is configured
-- Sources for CGAL component library 'CGAL_Qt3' detected
-- Sources for CGAL component library 'CGAL_Qt5' detected
Configuring libCGAL_Qt5
-- libCGAL_Qt5 is missing the dependencies: Qt5Svg Qt5 cannot be
configured.
-- Sources for CGAL component libraries
'CGAL_Core;CGAL_ImageIO;CGAL_Qt3;CGAL_Qt5' detected
So it can sense the CGAL_Qt5.
I think the problem is listed in the CHANGES file:
To
compile libCGAL_Qt5 and demos, you must set the cmake or environment
variable Qt5_DIR to point to the path to the directory containing the
file
Qt5Config.cmake created by your Qt5 installation. If you are using the
open
source edition it should be /path-to/qt-everywhere-opensource-src-
<version>/qtbase/lib/cmake/Qt5.
So apparently libCGAL_Qt5 has to be compiled i.e. built and this was not
clearly
specified in the doc.
Moreover, I don't how to do it. Oh I can find Qt5Config.cmake and it is
correctly
listed in CMakeCache.txt. I just have no idea how to build libCGAL_Qt5
best wishes
Tony
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/visualizing-CGAL-objects-tp4661624p4661659.html
- Re: [cgal-discuss] visualizing CGAL objects, tcscott, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Sebastien Loriot (GeometryFactory), 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Monique Teillaud, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Daniel Duque, 03/02/2016
- Re: [cgal-discuss] visualizing CGAL objects, Phil Weir, 03/03/2016
- Re: [cgal-discuss] visualizing CGAL objects, Adam Getchell, 03/03/2016
