- To:
- Subject: Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs
- Date: Thu, 31 Mar 2016 09:08:34 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Ra87QxRssC1rwOery8ZociiqF9psv+yvbD5Q0YIujvd0So/mwa64bByN2/xhgRfzUJnB7Loc0qyN4/CmAz1LscvJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviq9uJMk4Y2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQqIjULYNDCg6K3tno4rwpBzbRE2O4GEdWyMYiF1TEg3d5Vb7WJn29SD1v+441CiBNtDtVuMIXmGp4K5vDRPpkywaLCUR8WfNi8U2grgIjgimoklSzY+cToaaOf42Kq7TfN0dSmdFdslUXi1FRIi7at1cXKI6Ie9Eotyl9BM1phykCFz0CQ==
You cannot do it.
The offset (or inset) of a (linear) polygon is a generalized polygon that comprises linear segments and circular arcs, but the circular arcs do not intersect each other. (There is at least one segment between any two arcs). ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Wed, Mar 30, 2016 at 4:16 PM, Samuel Hornus <> wrote:
Hi,
From the documentation, the Minkoswki package can compute exact or approximate
offset and inset of polygons, resulting in a General_polygon_set_2 made of line
segments and circle arcs.
And General_polygon_set_2 can be manipulated via boolean operations.
There seem to be a missing element : the ability to inset or offset a General_polygon_set_2 which already comprises some circle arcs (instead of being made of 100% pure line segments).
It seems to me (naively) that this should be possible since the offset or inset of a piece of boundary which is a circular arc is itself a circular arc, so that the offset or inset of a General_polygon_set_2<Gps_circle_segment_traits_2>
should be, as well, a General_polygon_set_2<Gps_circle_segment_traits_2>
To sum up, can I do this with CGAL?
typedef General_polygon_set_2<Gps_circle_segment_traits_2> CoolShape;
CoolShape A, B, C;
C = approximate_inset(B, 300, 1.0).intersection( C );
(I believe that it’s not possible since, currently, B is expected to be purely linear.)
Thank you in advance,
Samuel
- [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Samuel Hornus, 03/30/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Efi Fogel, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Monique Teillaud, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Pratyush Pranav, 03/31/2016
