- To:
- Subject: Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs
- Date: Thu, 31 Mar 2016 14:00:30 +0200
On 31 Mar 2016, at 08:08, Efi Fogel <> wrote:
What you describe may end up with a generalized polygon that have consecutive arcs. Representing the vertices requires a higher order algebraic number.
Hi,
A quick comment only on this specific aspect. Intersecting two circles should not require higher degree than intersecting a circle and a line. In both cases, it is degree 2.
Best,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Samuel Hornus, 03/30/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Efi Fogel, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Monique Teillaud, 03/31/2016
- Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs, Pratyush Pranav, 03/31/2016
