Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL
- To:
- Subject: Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL
- Date: Thu, 21 Apr 2016 14:17:20 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:5tEjHBy9sgoZMYXXCy+O+j09IxM/srCxBDY+r6Qd0ekRIJqq85mqBkHD//Il1AaPBtWLrawUwLOL6OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZrnnLnvoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JYGUb2jFBBECR/hH3GJz4tW2j68Jg0y3cNMawULNiCmfq1LtiVBK90HRPDDU+6myC0sE=
Hi Petros,
I am also trying to compute the normal of a polyhedron_3 mesh at each
vertex. And I've tried using compute_vertex_normal function you mentioned
here, but I got NaN value. Here is my code:
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
for (Vertex_iterator v_it = polyhedron.vertices_begin(); v_it !=
polyhedron.vertices_end(); v_it++){
Kernel::Vector_3 v_n = compute_vertex_normal<Polyhedron::Vertex,
Kernel>(Polyhedron::Vertex(v_it->point()));
Could you tell me which part is wrong here? Thank you very much.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Properly-oriented-Polyhedron-3-vertex-normals-for-rendering-with-OpenGL-tp4661567p4661861.html
- Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL, Zhe Cao, 04/21/2016
- Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL, Sebastien Loriot (GeometryFactory), 04/22/2016
- Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL, Zhe Cao, 04/23/2016
- Re: [cgal-discuss] Properly oriented Polyhedron_3 vertex normals for rendering with OpenGL, Petros Kataras, 04/24/2016
