- To: "" <>
- Subject: Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2
- Date: Fri, 8 Jul 2016 20:24:33 +0200 (CEST)
On Fri, 8 Jul 2016, Grzegorz JABLONSKI wrote:
I am trying to compile Alpha_shape_2 using Periodic_Delaunay_Triangulation_2.
Here is code I use:
// CGAL headers
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Periodic_2_triangulation_filtered_traits_2.h>
#include <CGAL/Periodic_2_Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <CGAL/Alpha_shape_2.h>
//Typedefs
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
typedef CGAL::Periodic_2_triangulation_traits_2<K> GT;
typedef CGAL::Periodic_2_triangulation_vertex_base_2<GT> Vb;
typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned, GT, Vb> Vb_info;
typedef CGAL::Periodic_2_triangulation_face_base_2<GT> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb_info, Fb> Tds;
typedef CGAL::Periodic_2_Delaunay_triangulation_2<GT, Tds> PDT;
typedef PDT::Point Point;
typedef PDT::Point Point_2;
typedef CGAL::Alpha_shape_2<PDT> Alpha_shape_2;
When I try to initialize Alpha_shape_2 object I get errors listed below. Any
idea if what I'm trying to do is possible?
One thing that is suspicious is that you are not using Alpha_shape_vertex_base_2.
Marc Glisse
- [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/08/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/08/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/09/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/09/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Andreas Fabri, 07/10/2016
