- To: "" <>
- Subject: RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2
- Date: Sat, 9 Jul 2016 19:17:29 +0000
- Accept-language: en-US, de-AT
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:BeaKohDTC7hpACZB9+TqUyQJP3N1i/DPJgcQr6AfoPdwSP/5rsbcNUDSrc9gkEXOFd2CrakV06yN6Ou5Az1IyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWD14LsjKvrocybSj4LrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD888n7NNKBKXmY7wjH/sfFyUjK2lz5cvxtBCFQxHI/WoZSmxRkxxGBE/O4xj+G5vwqSDnrfEu5C7Pd8b5RLRxVTW55LpwUzfpjj0GPng36iuf3sd/haYerBO6rAFk2KbVZpuUPbxwZPWOU8kdQD9uRNRcWCtbEMueRqErKMw6HscQ+4bntVYBqgGsQwulDufozCRLh1f3xrF82u9nGB2Qj19oJM4HrHmB9Ia9D6wVS+3glKQ=
On Sat, 9 Jul 2016, Grzegorz JABLONSKI wrote:
> Ok, my mistake. Here is the complete code:
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
> #include <CGAL/Periodic_2_triangulation_filtered_traits_2.h>
> #include <CGAL/Periodic_2_Delaunay_triangulation_2.h>
> #include <CGAL/Triangulation_vertex_base_with_info_2.h>
> #include <CGAL/Alpha_shape_2.h>
> //**********TYPEDEFS********************
> typedef CGAL::Exact_predicates_exact_constructions_kernel K;
> typedef CGAL::Periodic_2_triangulation_traits_2<K> GT;
> typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned, K> Vb_info;
> typedef CGAL::Alpha_shape_vertex_base_2<K, Vb_info> Vb;
> typedef CGAL::Alpha_shape_face_base_2<K> Fb;
> typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
> typedef CGAL::Periodic_2_Delaunay_triangulation_2<GT, Tds> PDT;
> typedef CGAL::Alpha_shape_2<PDT> Alpha_shape_2;
> int main()
> Alpha_shape_2 as;
> This time there is a problem with using Dt::OUTSIDE_CONVEX_HULL in Alpha_shape_2.h
Thanks. Periodic_3_triangulation_3.h has:
OUTSIDE_CONVEX_HULL, // unused, for compatibility with Alpha_shape_3
OUTSIDE_AFFINE_HULL }; // unused, for compatibility with Alpha_shape_3
(not sure that's the best way to go about it, but as long as it works...)
and the 2D version doesn't. Don't hesitate to file an issue on github to
make sure this isn't forgotten (you could even try a pull request).
Marc Glisse
> int main()
> Alpha_shape_2 as;
Marc Glisse
- [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/08/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/08/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/09/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/09/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Andreas Fabri, 07/10/2016
