- To: "" <>
- Subject: RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2
- Date: Sat, 9 Jul 2016 12:07:52 +0200 (CEST)
On Sat, 9 Jul 2016, Grzegorz JABLONSKI wrote:
The same error occurs, when I use Alpha_shape_vertex_base_2:
Please don't post those random lists of typedefs, always post a MCVE (minimum complete verifiable example), that is:
* include the #includes and the instanciation (I should be able to copy-paste, compile, and immediatly get the same error)
* remove anything irrelevant like Point
You still don't seem to be using Alpha_shape_vertex_base_2, the Vb typedef is not used anywhere.
Marc Glisse
- [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/08/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/08/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Grzegorz JABLONSKI, 07/09/2016
- RE: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Marc Glisse, 07/09/2016
- Re: [cgal-discuss] Alpha_shape_2 using Periodic_2_Delaunay_Triangulation_2, Andreas Fabri, 07/10/2016
