cgal-discuss - [cgal-discuss] Mesh Segmentation Trouble
  • To:
  • Subject: [cgal-discuss] Mesh Segmentation Trouble
  • Date: Sun, 14 Aug 2016 15:20:09 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:xkFoghdwnrQlZYTM9eT9UBl2lGMj4u6mDksu8pMizoh2WeGdxc68ZB7h7PlgxGXEQZ/co6odzbGH6ua5AiddsN7B6ClEK80UEUddyI0/pE8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUrDbg8n/7e2u4ZqbO1wO32vkJ+opZ0jn5UWJ749N0NMkcv5wgjLy4VJwM9xMwm1pIV/B1z3d3eyXuKBZziJLpvg6/NRBW6ipN44xTLhfESh0ezttvJ6j5lH/Sl6E6XIYF2kXiRFVGBPt7RfgX563vDGpmPB63XyiNMfySocP0DKp76p5AEvwzjwOMTU5/XOG1uR/iatapFSqoBkpkN2cW52cKPcrJvCVRtgdX2cUBss=
Hi,
Lately I've been working with CGAL's mesh segmentation functionalities and I'm having some problems achieving different segmentations through number_of_clusters and smoothing_lambda parameters.
I'm using your "elephant.off" mesh as an example, and as I try to get the results you expose in your documentation for Surface Mesh Segmentation, I'm not able to get the same kind of segmentation.
Even though I change the values of the parameters, I still get the same segmentation in every iteration.
Could I get a hint of what I'm doing wrong?
Regards,
Pablo Sánchez
