cgal-discuss - Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • To:
  • Subject: Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • Date: Sun, 11 Sep 2016 01:25:00 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:SS+UUhV+J5BglpeUm8cYvg1ClSnV8LGtZVwlr6E/grcLSJyIuqrYZhGCt8tkgFKBZ4jH8fUM07OQ6PG5HzJeqs/e6jhCKMUKDE5dz51O3kQJO42sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx/q+2+36wZDPeQIA3GP7OuIrakvo5lyO7IFW2dIkcfdpjEOR4zNhQKd//StQP1WdnhLxtI+b3aVI1GBugc8n7NNKSq7gfq41HvRyBTUiNH0ptoWw7UGQBVjH2nxJWWofll9EAhPO8Qrhdpb3qCrz8ORniweAOsijYL41ERql4KpvAEvlhiYJMDE09EnYj8VxiORQpxf39E83+JLdfIzAbKk2RajaZ95PHWc=
What number type are you using?  Better yet, could you share the code?
On Sep 10, 2016 18:31, "Christopher Mitchell" <> wrote:
I'm attempting to determine if two Polygon_2s overlap in anyway, ie, share any portion of their interiors, including one being entirely contained by the other. In most cases this works, but for a few polygon pairs, do_intersect() returns false unexpectedly. I make sure (1) all polygons are simple (2) all polygons are not oriented CGAL::CLOCKWISE (I call .reverse_orientation() on the polys if they are CGAL::CLOCKWISE), and (3) that the starting vertex is not duplicated. I have attached an example of a polygon pair for which do_intersect() returns false. Thanks in advance for any insight; I'd be happy to provide additional information as necessary.
