cgal-discuss - Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • To:
  • Subject: Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • Date: Wed, 14 Sep 2016 14:20:19 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:YLnDMR/mA4CeS/9uRHKM819IXTAuvvDOBiVQ1KB80OMcTK2v8tzYMVDF4r011RmSDNydtKgP17qe8/i5HzdRudDZ6DFKWacPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvjotuMOU4U1HL9Oeo0d0Tu612J94E/ushLEu4J0BzHo39FKax95FhDAhatpSv6/dq655V58i5d6LoL/s9EVrjmLexjFeQLRAIPaD9uoZW3/VmeFUrcrkYaSXgcxxpUHxDevla9RYb0qiK8t+xn2SDcM9exVqExQT3l7qFlT1jjhy4DcjI462rKkdcjsKUOqx2oo1lzwpXffZqOHPt4ZKLUO90AFkRbWcMEfipNGI61dMMhBuAbPK4Mpo/xvVYHtl2wDAO2BcvgxzhNi2PszKMz2PgmCxCA1wslSYFd+E/Ipcn4Yf9BGdu+y7PFmGibYg==
Well, Efi, the 2D constrained triangulation should woek with Epic.
Christopher, can you please put the example that crashes on https://gist.github.com/
Best,
Andreas
On 14/09/2016 14:11, Efi Fogel wrote:
The choice whether to use Epic or Epec is not for you (the user) to
make. If it had been, then all users would have chosen Epic over Epec.
If constructions take place while computing, and the implementation is
sensitive to inexactness, then Epec must be used. Sometimes
constructions occur only to produce intermediate results; even then,
Epec is required. If the input points are far apart from each other this
still cannot guarantee correct computation, because the computation can
still reach a stage of uncertainty, and yes, when the computation
reaches a stage of uncertainty, anything can happen, including a segfault.
Let me reiterate, in order to avoid segfaults caused by limited
precision arithmetic, we need to avoid reaching stages of uncertainty,
and Epec does exactly that.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
On Tue, Sep 13, 2016 at 11:29 PM, Christopher Mitchell
<mailto:>>
wrote:
I've been running into a weird segfault with constrained Delauney
triangulation of two perfectly innocent polygons with coordinates on
the order of 10^2 units as well; are you telling me that the
underlying constructions are expected to segfault in some way if
there's a math error? That seems like bafflingly bugged behavior to
me. I note that applying a scaling factor of 10^-2 to the
coordinates in the example I have here made the code work properly;
is there some sort of unstated bound on coordinate magnitude for
inexact constructions that I should be obeying, like translating and
scaling all of my operations to [-10, 10], for example?
I should clarify that my hesitation to switch to exact constructions
is twofold: (1) the slowdown of using those constructions. I'm
attempting to write very performant code that will be executed on
millions of objects; (2) I see that exact constructions are not
drag-and-drop; I'll have to sprinkle conversions between doubles and
gmp numbers all over the place.
Thanks in advance for your elucidations!
On Tue, Sep 13, 2016 at 5:42 AM, Efi Fogel
<mailto:>>
wrote:
When I run the program as is (using inexact construction, I get
a core dump, which is most probably caused by the inexact
constructions.
When I run the program with an exact construction kernel, I get
the correct result.
You can simply:
void dumpPoly(CGALPolygon& poly) { std::cout << poly << std::endl; }
When using Exact_predicates_exact_constructions_kernel
____ _ ____ _
_/
On Mon, Sep 12, 2016 at 10:48 PM, Christopher Mitchell
<mailto:>>
wrote:
Sebastien: Thanks for the advice. Unfortunately, for speed
purposes I'd prefer to stick with inexact constructions.
This polygon pair doesn't seem like it's really approaching
the limits of numeric precision in terms of the huge overlap
area.
Efi: Ask and you shall receive. This code is a little
unwieldy for a minimum working example (102 lines), but I
figure its longevity will be better here than in a Pastebin.
To my great frustration, I tried removing points, and the
problem remained, but when I tried subtracting 100.0 from
every X coordinate, it indicated that the polygons
intersected. Working with doubles, the intersection
definitely shouldn't be hitting odd precision problems with
coordinates that are only on the order of 10^2 units. This
seems like it could possibly be a bug?
Thanks,
Christopher
// -----snip-----
#include <stdio.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Boolean_set_operations_2.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel
CGAL_Kernel;
typedef CGAL_Kernel::Point_2 CGALPoint;
typedef CGAL::Polygon_2<CGAL_Kernel> CGALPolygon;
double pts_p1[][2] = {
{138.434248, 54.124268},
{156.251888, 53.447439},
{159.268861, 55.635141},
{168.750594, 82.497614},
{165.721545, 83.640381},
{159.550635, 86.191099},
{149.385779, 90.040283},
{130.971384, 97.216211},
{119.770956, 101.497880},
{112.218620, 104.432790},
{109.481271, 93.899521},
{108.693051, 87.351571},
{108.600034, 80.589390},
{109.019489, 73.333375},
{109.398422, 60.659113},
{109.614696, 54.943998},
{128.132617, 54.352682}
double pts_p2[][2] = {
{139.434399, 57.599339},
{155.707971, 56.738629},
{156.812714, 57.672514},
{119.770956, 101.49788},
{112.218620, 104.43279},
{110.103104, 59.601234},
{127.188178, 57.950231},
{126.599293, 61.485162},
{124.600343, 71.709878},
{139.439351, 66.181265},
{139.584575, 60.776208}
int nodes2Polygon(const double pts[][2], const size_t size,
printf("Generating %zu-point poly\n", size);
// Copy points into polygon. Omit the last point if
it's a copy of the first point.
for (size_t i = 0; i < size; i++) {
if (i == 0 || i != (size - 1) || (pts[i][0]
!= pts[0][0] || pts[i][1] != pts[0][1])) {
CGALPoint point(pts[i][0], pts[i][1]);
// Make sure the point is not
identical to the previous point in the poly.
if (!poly.size() || point !=
*std::prev(poly.vertices_end())) {
poly.push_back(point);
if (!poly.is_simple()) {
return -1;
// Correct orientation to make it an outline, not a hole
if (poly.orientation() == CGAL::CLOCKWISE) {
poly.reverse_orientation();
return 0;
for(auto it = poly.vertices_begin(); it !=
poly.vertices_end(); it++) {
printf("%f %f\n", it->x(), it->y());
printf("\n");
int main(int argc, char* argv[]) {
CGALPolygon p1;
CGALPolygon p2;
nodes2Polygon(pts_p1, sizeof(pts_p1) /
sizeof(double) / 2, p1);
dumpPoly(p1);
nodes2Polygon(pts_p2, sizeof(pts_p2) /
sizeof(double) / 2, p2);
dumpPoly(p2);
if (CGAL::do_intersect(p1, p2)) {
printf("Polygons intersect\n");
} else {
printf("Polygons do not intersect\n");
if (CGAL::do_intersect(p2, p1)) {
} else {
return 0;
On Mon, Sep 12, 2016 at 6:08 AM, Sebastien Loriot
(GeometryFactory)
<mailto:>>
wrote:
The kernel used does not have exact constructions.
Try again with
CGAL::Exact_predicates_exact_constructions_kernel
Sebastien.
On 09/12/2016 12:00 PM, Efi Fogel wrote:
It would easier if you just send the code and the
input polygon.
This way we can quickly try to reproduce the problem.
____ _ ____ _
_/
On Mon, Sep 12, 2016 at 1:03 AM, Christopher
Mitchell
<mailto:>
<mailto:
<mailto:>>>
wrote:
Thanks for the quick response. The code is
sufficiently trivial (ie,
a single if (CGAL::do_intersect(poly1, poly2)) {
... }) that I'm not
sure it would help. I'm using a simple loop to
convert a set of
non-CGAL points into a Polygon_2, making sure to
not duplicate the
starting point, as you can see from the image
attached to the first
post. My polygons are
CGAL::Polygon_2<CGAL_Kernel>, where
CGAL_Kernel is
CGAL::Exact_predicates_inexact_constructions_kernel.
I hope this helps. Thanks!
On Sat, Sep 10, 2016 at 6:25 PM, Efi Fogel
<mailto:>
<mailto:
<mailto:>>>
wrote:
What number type are you using? Better yet,
could you share the
code?
On Sep 10, 2016 18:31, "Christopher
Mitchell"
<mailto:>
<mailto:
<mailto:>>>
wrote:
I'm attempting to determine if two
Polygon_2s overlap in
anyway, ie, share any portion of their
interiors, including
one being entirely contained by the
other. In most cases
this works, but for a few polygon pairs,
do_intersect()
returns false unexpectedly. I make sure
(1) all polygons are
simple (2) all polygons are not oriented
CGAL::CLOCKWISE (I
call .reverse_orientation() on the polys
if they are
CGAL::CLOCKWISE), and (3) that the
starting vertex is not
duplicated. I have attached an example
of a polygon pair for
which do_intersect() returns false.
any insight; I'd be happy to provide
additional information
as necessary.
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
