- To:
- Subject: Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
- Date: Mon, 12 Sep 2016 13:00:29 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:BocYex33yb2FNdHCsmDT+DRfVm0co7zxezQtwd8ZsegTKfad9pjvdHbS+e9qxAeQG96KsrQa26GP7OigATVGusfZ9ihaMdRlbFwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oMyKJVsYz2PiKfMqdVPt/F2X7pFXyaJZaY8JgiPTpXVJf+kEjUhJHnm02yjG28Gr4ZR4+D5Rsf9yv+RJUKH9YrhqBecAVGduYCgJ45jguhDHCAeO/XABSX4+kxxSAgGD4gupcI32t37XuOs19i6VMMm+Gb06WDql4KpvYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
It would easier if you just send the code and the input polygon.
This way we can quickly try to reproduce the problem. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Mon, Sep 12, 2016 at 1:03 AM, Christopher Mitchell <> wrote:
Thanks for the quick response. The code is sufficiently trivial (ie, a single if (CGAL::do_intersect(poly1, poly2)) { ... }) that I'm not sure it would help. I'm using a simple loop to convert a set of non-CGAL points into a Polygon_2, making sure to not duplicate the starting point, as you can see from the image attached to the first post. My polygons are CGAL::Polygon_2<CGAL_Kernel>, where CGAL_Kernel is CGAL::Exact_predicates_inexact_constructions_kernel. I hope this helps. Thanks!On Sat, Sep 10, 2016 at 6:25 PM, Efi Fogel <> wrote:What number type are you using? Better yet, could you share the code?
On Sep 10, 2016 18:31, "Christopher Mitchell" <> wrote:I'm attempting to determine if two Polygon_2s overlap in anyway, ie, share any portion of their interiors, including one being entirely contained by the other. In most cases this works, but for a few polygon pairs, do_intersect() returns false unexpectedly. I make sure (1) all polygons are simple (2) all polygons are not oriented CGAL::CLOCKWISE (I call .reverse_orientation() on the polys if they are CGAL::CLOCKWISE), and (3) that the starting vertex is not duplicated. I have attached an example of a polygon pair for which do_intersect() returns false. Thanks in advance for any insight; I'd be happy to provide additional information as necessary.
- [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Christopher Mitchell, 09/10/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Efi Fogel, 09/11/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Christopher Mitchell, 09/12/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Efi Fogel, 09/12/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Sebastien Loriot (GeometryFactory), 09/12/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Efi Fogel, 09/13/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Christopher Mitchell, 09/13/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Efi Fogel, 09/14/2016
- Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?, Andreas Fabri, 09/14/2016
