cgal-discuss - Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • To:
  • Subject: Re: [cgal-discuss] Unexpected Polygon_2 do_intersect() Behavior?
  • Date: Mon, 12 Sep 2016 12:08:10 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:he9MFRaAZc+HJZJJDeVe0HX/LSx+4OfEezUN459isYplN5qZpsWzbnLW6fgltlLVR4KTs6sC0LuP9f6wEjZdqdbZ6TZZL8wKD0dEwewt3CUeQ+e9QXXhK/DrayFoVO9jb3RCu0+BDE5OBczlbEfTqHDhpRQbGxH4KBYnbr+tQt2a3IyL0LW59JTXJglJnzGgeqhaLROsrAyXuNNFr5FlL/N78RbDq2BUeulQjUdvP1OUg168ycq3+ZN/6TV+svk98NRREO+yK788SqZZCyhgNmQd68jitB2FRgyKsChPGl4KmwZFVlCWpCrxWY3853P3
The kernel used does not have exact constructions.
Try again with CGAL::Exact_predicates_exact_constructions_kernel
Sebastien.
On 09/12/2016 12:00 PM, Efi Fogel wrote:
It would easier if you just send the code and the input polygon.
This way we can quickly try to reproduce the problem.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
On Mon, Sep 12, 2016 at 1:03 AM, Christopher Mitchell
<mailto:>>
wrote:
Thanks for the quick response. The code is sufficiently trivial (ie,
a single if (CGAL::do_intersect(poly1, poly2)) { ... }) that I'm not
sure it would help. I'm using a simple loop to convert a set of
non-CGAL points into a Polygon_2, making sure to not duplicate the
starting point, as you can see from the image attached to the first
post. My polygons are CGAL::Polygon_2<CGAL_Kernel>, where
CGAL_Kernel is CGAL::Exact_predicates_inexact_constructions_kernel.
I hope this helps. Thanks!
On Sat, Sep 10, 2016 at 6:25 PM, Efi Fogel
<mailto:>>
wrote:
What number type are you using? Better yet, could you share the
code?
On Sep 10, 2016 18:31, "Christopher Mitchell"
<mailto:>>
wrote:
I'm attempting to determine if two Polygon_2s overlap in
anyway, ie, share any portion of their interiors, including
one being entirely contained by the other. In most cases
this works, but for a few polygon pairs, do_intersect()
returns false unexpectedly. I make sure (1) all polygons are
simple (2) all polygons are not oriented CGAL::CLOCKWISE (I
call .reverse_orientation() on the polys if they are
CGAL::CLOCKWISE), and (3) that the starting vertex is not
duplicated. I have attached an example of a polygon pair for
which do_intersect() returns false. Thanks in advance for
any insight; I'd be happy to provide additional information
as necessary.
