- To:
- Subject: [cgal-discuss] Problem with intersection
- Date: Mon, 31 Oct 2016 22:40:48 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:nLJwtBXprN7w5HH357iPFun2oNzV8LGtZVwlr6E/grcLSJyIuqrYZROFt8tkgFKBZ4jH8fUM07OQ6PG6HzxYqsvY+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYbAxMwTa8erhvNw6erAPLt8BQj5ExBLw2z073q3tJd6x/12J6JBrHgR+679Wx7p9L/CFZuvZn/MlFB/apN58kRKBVWWx1e1s+49fm4EHO
Hi all,
I have a geometry volume and a plane(their vertices), the Delaunry triangulation is applied on both of them(their vertices). For the geometry volume i get 16 facets and for the plane i get two facets. I need to find intersection between these two. It seems in some case the plane which is inside the volume doesn't have intersection with any facets of volume. I searched for changing resolution of triangulation but it seems there is not such a option. I've attached an image which depicts the situation and also a fig file which you can rotate the image to see what is the problem. The blue stars are intersection points for down red triangle.
images:
Is there anything that i can do, maybe with resolution or with intersection or do i need to go with another approach?
Thanks in advance!
Best,
-- Vahid
- [cgal-discuss] Problem with intersection, Vahid Azizi, 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/02/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/03/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/11/2016
