- To:
- Subject: Re: [cgal-discuss] Problem with intersection
- Date: Tue, 1 Nov 2016 08:36:08 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:VowHfB+ctZ7cm/9uRHKM819IXTAuvvDOBiVQ1KB90u4cTK2v8tzYMVDF4r011RmSDN+du6oP0rKH++C4ACpbvsbH6ChDOLV3FDY7yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9EM2uRdWX15j/l73qus6bXwIdjzW0ZfZ+LQ69sB7KnsgQm4prbKgrmTXTpX4dMd9bz2pzOVOemV7Y4d2x+4IrswtdvPcs69RRf6zxY6MiXP0SRGA9N2cv5cr38xzHZQSK73oYFG4Rl0wbUED+8BjmU8Kp4WPBve1n1XzHZcA=
It is not clear (at least to me) what you are trying to do.
What are you looking for? An intersection function for 2 triangle soups?
A 3D constrained triangulation?
Sebastien.
On 11/01/2016 03:40 AM, Vahid Azizi wrote:
Hi all,
I have a geometry volume and a plane(their vertices), the Delaunry
triangulation is applied on both of them(their vertices). For the
geometry volume i get 16 facets and for the plane i get two facets. I
need to find intersection between these two. It seems in some case the
plane which is inside the volume doesn't have intersection with any
facets of volume. I searched for changing resolution of triangulation
but it seems there is not such a option. I've attached an image which
depicts the situation and also a fig file which you can rotate the image
to see what is the problem. The blue stars are intersection points for
down red triangle.
images:
https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing
Is there anything that i can do, maybe with resolution or with
intersection or do i need to go with another approach?
Thanks in advance!
Best,
/Vahid/
- [cgal-discuss] Problem with intersection, Vahid Azizi, 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/02/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/03/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/11/2016
