cgal-discuss - Re: [cgal-discuss] Problem with intersection
  • To:
  • Subject: Re: [cgal-discuss] Problem with intersection
  • Date: Thu, 3 Nov 2016 14:43:42 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:X1bXXxFifOH13LFbK2Qv9Z1GYnF86YWxBRYc798ds5kLTJ75os6wAkXT6L1XgUPTWs2DsrQf2rCQ4/+rAjNIoc7Y9itdINoUD15NoP5VtjJjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScaBx/mxzP24rp3Pfx1T1n36eqJ3NBzwrAPLt8BQj5ElMbc00hKOo31GfKNdympsYF6ShB3h/dzjwJk2+CtZv7ct9tVLTL7hV6U+V71RSjo8YE4v48i+/yLORwKU+noRVC0ylQBJBBSNrD73WZL8rjHrmON2xC6ALIy8BeQvXTO47qB3DhrsoCgCPj89tmrQj5oj3+pgvBu9qkknkMbva4aPOa8mcw==
Sorry, it is still not clear to me what you want to do.
I don't know if you want to compute the symmetric difference
or something else.
Sebastien.
On 11/02/2016 07:00 AM, Vahid Azizi wrote:
Sorry, i tried to keep the message so short. anyway, I am doing
following steps:
1) I have some points which they are supposed to be a polyhedron, It is
the result by delaunry triangulation over these points: polyhedron
<https://drive.google.com/file/d/0B6aDrBbewOPBUTlZaHlSYmsxWkE/view?usp=sharing>
2) i have another set of points which they are supposed to be a plane,
after delanury triangulation over this set I have: plane
<https://drive.google.com/file/d/0B6aDrBbewOPBSUlVdTdlUUl2XzQ/view?usp=sharing>
3) in last step i want to find the subsurface of the plane which is not
in intersection with polyhedron. My idea here is to iterate over all
triangles and keep all intersection points in a list, then i can create
a convex hull out of intersection points. So, i have the subsurface
which is in intersection with polyhedron. I did these steps for another
purpose before and it works. I didn't try to extract the subsurface
which is not in intersection but there must be a way for that.
Now, the problem is with explained idea as you see in this image
<https://drive.google.com/file/d/0B6aDrBbewOPBV2J2VktfUEFpN0U/view?usp=sharing>,
intersection function doesn't return any intersection points for upper
red triangle(upper part of the plane) . But there are two intersection
points for down red triangle which are marked with blue star. As i spent
some time for finding the reason it seems the problem is this triangle
doesn't have any intersection with edges of triangles in polyhedron. I
think if i could change the resolution of triangulation i could solve
this problem. If i have more fined triangles in polyhedron with high
probability there will be intersection with their edges. As i searched
it seems there is not any option for modifying resolution of
triangulation. Also the fig file for this issue is uploaded here
<https://drive.google.com/file/d/0B6aDrBbewOPBR1RtVUE5ZkZVUE0/view?usp=sharing>,
maybe it could give you better view.
My questions are:
Is there any better way to find the subsurface of the plane which is not
in intersection with polyhedron? Here just assume i have to two 3D
polyhedrons which i want to find the part which doesn't have intersection.
if there is not any better way, how could i solve the current issue?
Thanks in advance,
Best,
On Tue, Nov 1, 2016 at 3:36 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
It is not clear (at least to me) what you are trying to do.
What are you looking for? An intersection function for 2 triangle soups?
A 3D constrained triangulation?
Sebastien.
On 11/01/2016 03:40 AM, Vahid Azizi wrote:
Hi all,
I have a geometry volume and a plane(their vertices), the Delaunry
triangulation is applied on both of them(their vertices). For the
geometry volume i get 16 facets and for the plane i get two
facets. I
need to find intersection between these two. It seems in some
case the
plane which is inside the volume doesn't have intersection with any
facets of volume. I searched for changing resolution of
triangulation
but it seems there is not such a option. I've attached an image
which
depicts the situation and also a fig file which you can rotate
the image
to see what is the problem. The blue stars are intersection
points for
down red triangle.
images:
https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing
<https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing>
Is there anything that i can do, maybe with resolution or with
intersection or do i need to go with another approach?
Thanks in advance!
Best,
/Vahid/
<https://sympa.inria.fr/sympa/info/cgal-discuss>
/Vahid/
