- To:
- Subject: Re: [cgal-discuss] Problem with intersection
- Date: Fri, 4 Nov 2016 07:29:26 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:O5fNrBKF1DktT8N0rNmcpTZWNBhigK39O0sv0rFitYgVIvjxwZ3uMQTl6Ol3ixeRBMOAuqgC27qd4vyocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+kQMiC34/mi6ibwN76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtKhY7j9Itvk928lFWKT8N+RkHP0LRAkgKH0/sc33qQHYH0zI/WoZSmxQkxxSAgGD4gu9RYb0qiK9t+xz326RMsTyCLw1Qj+/9Lw4dRnzlS1SNyIl6HqFzYtrnadDqVSgoQZ+ysjaesaOJf9md+Tce90dAmFOV8IUWy1aCZ6ndNgzCL8KMu9c6oX8vFATtgCWBA+2BeqpxCUbqGXx2Phw6OkrGBra3QEmV/YJqnXTsJ21G6oVVO2p1rjmxD7faOlHmH21vJPMdQogpu3KWLZYfs/YyE1pHATA2AbD4bf5Ni+Yg7xe+1OQ6PBtAL7+hg==
You can iterator over vertices using
[nef.vertices_begin(), nef.vertices_end()[
http://doc.cgal.org/latest/Nef_3/classCGAL_1_1Nef__polyhedron__3.html#af91bdaaa2b4324250d1bc15a38d30787
You can also get access to the half-facets:
[nef.halffacets_begin(), nef.halffacets_end()[
http://doc.cgal.org/latest/Nef_3/classCGAL_1_1Nef__polyhedron__3.html#a92eca2af31def19d96363904ce95881b
Sebastien.
On 11/04/2016 12:44 AM, Vahid Azizi wrote:
Sorry again! no, i don't want to calculate the symmetric difference.
I just want to calculate the difference, for clarification i uploaded
another image
<https://drive.google.com/file/d/0B6aDrBbewOPBSkJKOHkzSW1vVXc/view?usp=sharing>
which shows what i want. The bold black part which marked with an arrow
is the part that i want to extract if there is any.
do you have any suggestion for raised issue with explained method in
earlier email?
Also i tried another way with nef_polyhedron, first i create convex
hull for my two point sets, then convert them to nef_polyhedron and
apply difference operator over them, the code
<https://docs.google.com/document/d/1HKOlX4bWXEaJX3lmmwGtt67b07nu22yyPkJJ192iJko/edit?usp=sharing>
is uploaded here. i want to convert back the result of nef_polyhedron to
polyhedron but i get error about preconditions. I tried sample code in
the CGAL doc and the result nef couldn't pass is_simple() function. I
need just the vertices of extracted part. does not passing is_simple()
function mean the result of operator is not correct? if it is correct,
is there any way to get the vertices even without converting back to
polyhedron?
Thank you so much!
Best,
Vahid
On Thu, Nov 3, 2016 at 9:43 AM, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Sorry, it is still not clear to me what you want to do.
I don't know if you want to compute the symmetric difference
or something else.
Sebastien.
On 11/02/2016 07:00 AM, Vahid Azizi wrote:
Sorry, i tried to keep the message so short. anyway, I am doing
following steps:
1) I have some points which they are supposed to be a
polyhedron, It is
the result by delaunry triangulation over these points: polyhedron
<https://drive.google.com/file/d/0B6aDrBbewOPBUTlZaHlSYmsxWkE/view?usp=sharing
<https://drive.google.com/file/d/0B6aDrBbewOPBUTlZaHlSYmsxWkE/view?usp=sharing>>
2) i have another set of points which they are supposed to be a
plane,
after delanury triangulation over this set I have: plane
<https://drive.google.com/file/d/0B6aDrBbewOPBSUlVdTdlUUl2XzQ/view?usp=sharing
<https://drive.google.com/file/d/0B6aDrBbewOPBSUlVdTdlUUl2XzQ/view?usp=sharing>>
3) in last step i want to find the subsurface of the plane which
is not
in intersection with polyhedron. My idea here is to iterate over all
triangles and keep all intersection points in a list, then i can
create
a convex hull out of intersection points. So, i have the subsurface
which is in intersection with polyhedron. I did these steps for
another
purpose before and it works. I didn't try to extract the subsurface
which is not in intersection but there must be a way for that.
Now, the problem is with explained idea as you see in this image
<https://drive.google.com/file/d/0B6aDrBbewOPBV2J2VktfUEFpN0U/view?usp=sharing
<https://drive.google.com/file/d/0B6aDrBbewOPBV2J2VktfUEFpN0U/view?usp=sharing>>,
intersection function doesn't return any intersection points for
upper
red triangle(upper part of the plane) . But there are two
intersection
points for down red triangle which are marked with blue star. As
i spent
some time for finding the reason it seems the problem is this
triangle
doesn't have any intersection with edges of triangles in
polyhedron. I
think if i could change the resolution of triangulation i could
solve
this problem. If i have more fined triangles in polyhedron with high
probability there will be intersection with their edges. As i
searched
it seems there is not any option for modifying resolution of
triangulation. Also the fig file for this issue is uploaded here
<https://drive.google.com/file/d/0B6aDrBbewOPBR1RtVUE5ZkZVUE0/view?usp=sharing
<https://drive.google.com/file/d/0B6aDrBbewOPBR1RtVUE5ZkZVUE0/view?usp=sharing>>,
maybe it could give you better view.
My questions are:
Is there any better way to find the subsurface of the plane
which is not
in intersection with polyhedron? Here just assume i have to two 3D
polyhedrons which i want to find the part which doesn't have
intersection.
if there is not any better way, how could i solve the current issue?
Thanks in advance,
Best,
On Tue, Nov 1, 2016 at 3:36 AM, Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
It is not clear (at least to me) what you are trying to do.
What are you looking for? An intersection function for 2
triangle soups?
A 3D constrained triangulation?
Sebastien.
On 11/01/2016 03:40 AM, Vahid Azizi wrote:
Hi all,
I have a geometry volume and a plane(their vertices),
the Delaunry
triangulation is applied on both of them(their
vertices). For the
geometry volume i get 16 facets and for the plane i get two
facets. I
need to find intersection between these two. It seems in
some
case the
plane which is inside the volume doesn't have
intersection with any
facets of volume. I searched for changing resolution of
triangulation
but it seems there is not such a option. I've attached
an image
which
depicts the situation and also a fig file which you can
rotate
the image
to see what is the problem. The blue stars are intersection
points for
down red triangle.
images:
https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing
<https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing>
<https://drive.google.com/drive/folders/0B6aDrBbewOPBR2gwTE5JZm4yNnc?usp=sharing>>
Is there anything that i can do, maybe with resolution
or with
intersection or do i need to go with another approach?
Thanks in advance!
Best,
/Vahid/
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
/Vahid/
/Vahid/
- [cgal-discuss] Problem with intersection, Vahid Azizi, 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/01/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/02/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/03/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Sebastien Loriot (GeometryFactory), 11/04/2016
- Re: [cgal-discuss] Problem with intersection, Vahid Azizi, 11/11/2016
