- To:
- Subject: Re: [cgal-discuss] compile demo in ubuntu
- Date: Mon, 10 Jul 2017 18:03:53 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Monday, July 10, 2017 5:11:19 PM CEST Servenaz a ?crit :
> i've done it
> i got this warning:
> -- Configuring done
> CMake Warning at src/CMakeLists.txt:48 (add_library):
> Cannot generate a safe runtime search path for target CGAL_Qt5 because
> files in some directories may conflict with libraries in implicit
> directories:
> runtime library [libQt5OpenGL.so.5] in /usr/lib/x86_64-linux-gnu may be
> hidden by files in:
> /home/pc/src/Qt5.7.0/5.7/gcc_64/lib
> runtime library [libQt5Widgets.so.5] in /usr/lib/x86_64-linux-gnu may
> be hidden by files in:
> runtime library [libQt5Gui.so.5] in /usr/lib/x86_64-linux-gnu may be
> hidden by files in:
> runtime library [libQt5Core.so.5] in /usr/lib/x86_64-linux-gnu may be
> hidden by files in:
> Some of these libraries may not be found correctly.
> Call Stack (most recent call first):
> src/CGAL_Qt5/CMakeLists.txt:93 (collect_cgal_library)
> -- Generating done
> -- Build files have been written to: /home/pc/src/CGAL-4.10
> i thought it's just a warning
> how can i solve it
I agree that looks like a warning, and the command `make CGAL_Qt5` should
work without error.
However, it is strange. Be careful not to mix Qt5 versions: the version used
to compile /usr/local/lib/libQGLViewer-qt5.so should be used also to compile
libCGAL_Qt5, and any CGAL+Qt5 application you want to compile.
Laurent Rineau, PhD
- [cgal-discuss] compile demo in ubuntu, Servenaz, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Osama Fadel, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Servenaz, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/11/2017
- Re: [cgal-discuss] compile demo in ubuntu, Servenaz, 07/12/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/12/2017
