- To:
- Subject: Re: [cgal-discuss] compile demo in ubuntu
- Date: Wed, 12 Jul 2017 05:44:53 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:VSpQYhGNnXTswGeMAhwoP51GYnF86YWxBRYc798ds5kLTJ78ocSwAkXT6L1XgUPTWs2DsrQf2rWQ6/iocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbQhFgDiwbaluIBmqsA7cqtQYjYx+J6gr1xDHuGFIe+NYxWNpIVKcgRPx7dqu8ZBg7ipdpesv+9ZPXqvmcas4S6dYDCk9PGAu+MLrrxjDQhCR6XYaT24bjwBHAwnB7BH9Q5fxri73vfdz1SWGIcH7S60/VDK/5KlpVRDokj8KOTA5/m/JicJ/jqxbrg+uqBNjzIDZe52VOfhkc6/BYd8WWXRNU8BMXCJBGIO8aI4PAvIcM+lGtYn9uUUBrR2kCgitGejizSRHiWXt0qIg0OQhERvJ3AohH94Uq3TZrdH4ObwdUeCw1qbIzDHDY+lK1jf67YjFaxYsquyCU7J3dMre00gvFwXdg1WWs4PqJCia1uATvGSB8+VgUuevhmg6oA9yujii3togh4jXio4P1FzJ9St0zJwoKdC2RkN3e9GpHZVIuy2HNoZ6XNkuT39otSs00LEKpJC2cSYQxJknxRPSbeGMfZKS7RL5TumRJC91hHJ7d7K7gBa/6U2gy+P7Vsmu01ZGtCxFncPXuX8W0xzc9NKLRed6/kekwTqP1gbT5f9YIU0siKbWKoAtzqQumpcTv0nPBDL6lUv4gaOMeUgp9PCk6+H9bbXnop+cOZV0igb7Mqk2gcOwG/83PRINX2ib4+u80rzj8VfiQLhLivA7iabZsJXAKsQaoq61GRNa0oEm6xqnFTepzMwYnWUbLFJCYB+Ik4fpNEvKIPzhEPi/gk+snyt2x/DdJb3sGY7NL3jGkLf5Z7lx8U9cyAwpzdBe/Z1YEL8BIOigEnP24dfXBxt8Pw2vyPv8E/180JkfUCSBGPy3KqTX5GSF/PwiJeCeLNsfsTz0KPgs4f+oliFosVAYdKitm5AQbSbrTbxdP0yFbC+00Z86GmAQs19mQQ==
i change CGAL_DIR to /home/pc/src/CGAL-4.10/
it solved my problem
now i wanna run the executable file with "./Alpha_shape_3" command
i got :
The constructor with a QGLContext is deprecated, use the regular contructor
instead.
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL
are enabled
are enabled
QOpenGLWidget: Failed to create context
are enabled
composeAndFlush: makeCurrent() failed
it will continue until i close CGAL 3D Alpha shape
what's the problem?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/compile-demo-in-ubuntu-tp4662810p4662821.html
- [cgal-discuss] compile demo in ubuntu, Servenaz, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Osama Fadel, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Servenaz, 07/10/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/11/2017
- Re: [cgal-discuss] compile demo in ubuntu, Servenaz, 07/12/2017
- Re: [cgal-discuss] compile demo in ubuntu, Laurent Rineau (CGAL/GeometryFactory), 07/12/2017
