[cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
- To:
- Subject: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
- Date: Wed, 16 Aug 2017 15:10:52 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:L810XBQLIdUVuhxNkooL4jNalNpsv+yvbD5Q0YIujvd0So/mwa67YRyN2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnZBUin4YAF6L+CwFo/JhNmszMiz/YfSakNGnmmTe7R3eSe2rA7Rv85epYp/YvI1ywbbqXZFcP9+ymZhJFbVlBH5sJTjtKV/+jhd7qpyv/VLVr/3Kvw1
Hi all,
Although GSOC2017 has almost ended, I noticed that "Adding a Parallel Version of the Edge Simplification Algorithm" is still unsolved. I am interested in this problem and I have read some of the source codes and the papers mentioned in the document.
Has someone already started working on that? Can I continue my work?
Thanks a lot and best regards,
Zhichao
- [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?, Zhichao Liu, 08/16/2017
- Re: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?, Sebastien Loriot (GeometryFactory), 08/17/2017
