- To:
- Subject: [cgal-discuss] Cross compiling in mingw-w64
- Date: Wed, 16 Aug 2017 16:42:43 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Pyfy5BYorpki+Hyek3BE3Yn/LSx+4OfEezUN459isYplN5qZpsu5bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76vnYuHUD0OgNxY+j0AYXPlN+f1uao+pSVbR8bqiC6ZOZZJQ+yqh6Zn80bjpFjI+4ewx/IqXpBM7BdzGdlKkiSllX36c601JFm+iVU/fkm8pgTAu3BY60kQOkAX3wdOGcv6ZizuA==
I am having some compilation errors while using mingw-w64 to cross compile the CGAL library. I have read in some comments on some forums that CGAL has not been tested with mingw-w64, although in CGAL documentation there is no mention about this.
Here are the errors I am getting. I am using mingw-w64 on ArchLinux. ¿Has someone successfully compiled CGAL with mingw-w64?
Thanks,
Carlos Alegría
- [cgal-discuss] Cross compiling in mingw-w64, Carlos Alegria Galicia, 08/16/2017
- Re: [cgal-discuss] Cross compiling in mingw-w64, Sebastien Loriot (GeometryFactory), 08/17/2017
- Re: [cgal-discuss] Cross compiling in mingw-w64, Carlos Alegria Galicia, 08/17/2017
