cgal-discuss - Re: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
  • To:
  • Subject: Re: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
  • Date: Thu, 17 Aug 2017 02:49:04 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:AbgoARC/FBHDAgybTAIZUyQJP3N1i/DPJgcQr6AfoPdwSP76psbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760DgJBx+qNRZpPv+nXcnJnsGv3qaz/YfSakNGnn2mcLZqJVK3qwvW8cIZiI8nJqcqwQbSuSh0fLFdympsYF6ShB3h/dyY/Zh58i0Wtehy2dRHVPDIf6UzTbVfRBAnLihh4Mz2pxLOQACUznQZW2QS1BFPBl6Wv1nBQp7tv36i5aJG0y6AMJiuQA==
Hi, Sebastien,
    Thanks for your reply. It seems like there is already someone working on it and proposing a good enough solution. I thought for a while after I make the problem clear to myself. And my tentative idea is just like their implementation.
    So I am wondering whether there is another project available on http://www.cgal.org/project_ideas.html, such as  "Finalizing a Package for 2D Triangulations on the Sphere", "Reworking Intersection Functions", "Improving Poisson Surface Reconstruction" and "Improving Normal Orientation".
    Thanks for your patience.
Best regards,
Zhichao
2017-08-17 1:49 GMT-05:00 Sebastien Loriot (GeometryFactory) <>:
Hi,
thanks for the interest. We have started implementing an approach that
is using a decomposition of the mesh into connected patches with a
simplification of each patch in parallel + handling of neighboring
regions. If you want to implement another approach you are more than
welcome.
Best regards,
Sebastien.
On 08/16/2017 10:10 PM, Zhichao Liu wrote:
Hi all,
    Although GSOC2017 has almost ended, I noticed that "Adding a
Parallel Version of the Edge Simplification Algorithm" is still
unsolved. I am interested in this problem and I have read some of the
source codes and the papers mentioned in the document.
    Has someone already started working on that? Can I continue my work?
Thanks a lot and best regards,
Zhichao
