cgal-discuss - Re: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
  • To:
  • Subject: Re: [cgal-discuss] Is "Adding a Parallel Version of the Edge Simplification Algorithm" still an aviliable project?
  • Date: Thu, 17 Aug 2017 08:49:00 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:DFtHFh8Rrrmu8v9uRHKM819IXTAuvvDOBiVQ1KB+2+4cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS46tL2HV93a95DpXFhTkPhduPcz0HJTThoK5zbOc4ZrWNk9ziTC0eq9zIRP+iQLLt84KyctNJ6E0xwfTs1VBcPhR33IpbxrHhBL7/Ma34Nhm9wxfvvsg84hLVqCsLPdwdqBREDlzazN938bsrxSWFQY=
Hi,
thanks for the interest. We have started implementing an approach that
is using a decomposition of the mesh into connected patches with a
simplification of each patch in parallel + handling of neighboring
regions. If you want to implement another approach you are more than
welcome.
Best regards,
Sebastien.
On 08/16/2017 10:10 PM, Zhichao Liu wrote:
Hi all,
Although GSOC2017 has almost ended, I noticed that "Adding a
Parallel Version of the Edge Simplification Algorithm" is still
unsolved. I am interested in this problem and I have read some of the
source codes and the papers mentioned in the document.
Has someone already started working on that? Can I continue my work?
Thanks a lot and best regards,
Zhichao
