Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- Date: Tue, 14 Nov 2017 18:43:04 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Gb5TuRz7oM6p2TvXCy+O+j09IxM/srCxBDY+r6Qd0uISIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi54jcWXxn+LgFoPf/dG4jIjs3x2frh1YfUZlACvze3aKhuLRiw5SHWrMgRncMiBas2zxbVuGpmcu9Kwnl5ZBjbyw344d2x+4Il9iB4tPco9soGWqL/KfdrBYdEBSgrZjhmrPbgsgPOGFOC
The bug is fixed in this PR:
https://github.com/CGAL/cgal/pull/2598
Thanks for the report!
Sebastien.
On 11/07/2017 09:51 PM, sdobashi wrote:
Hi everyone,
I created a rectangular tube shaped Nef_polyhedron_3 object by subtracting
'box2' from 'box1' (fig1, 2).
The resultant nef polyhedron looks like what I expected (fig2).
However, when I converted this to Polyhedron_3 using
"CGAL::convert_nef_polyhedron_to_polygon_mesh" or "convert_to_polygon"
method,
The top and bottom of the rectangular tube were capped (fig3).
I attached the relevant code to the end of this message.
The output "diff12.off" has a rectilinear hole inside a box but the hole was
capped on the surface.
I want to preserve the shape like fig3
even after converting the Nef polyhedron to an ordinary Polyhedron.
Is there a way to prevent the covering on the surface
when converting Nef polygon to an ordinary polygon?
Thanks,
S Dobashi
Fig1
<http://cgal-discuss.949826.n4.nabble.com/file/t375861/fig1_box1_and_box2.png>
Fig2
<http://cgal-discuss.949826.n4.nabble.com/file/t375861/fig2_box1_minus_box2_as_Nef.png>
Fig3
<http://cgal-discuss.949826.n4.nabble.com/file/t375861/fig3_box1_minus_box2_as_Polyhedron.png>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Surface_mesh.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/boost/graph/convert_nef_polyhedron_to_polygon_mesh.h>
#include <sstream>
#include <fstream>
typedef CGAL::Exact_predicates_exact_constructions_kernel Exact_kernel;
typedef CGAL::Polyhedron_3<Exact_kernel> Polyhedron;
typedef CGAL::Surface_mesh<Exact_kernel::Point_3> Surface_mesh;
typedef CGAL::Nef_polyhedron_3<Exact_kernel> Nef_polyhedron;
void set_box1(Polyhedron& P)
std::stringstream ss;
ss << "OFF\n"
<< "8 6 0\n"
<< "0 0 0\n"
<< "1 0 0\n"
<< "1 1 0\n"
<< "0 1 0\n"
<< "0 0 1\n"
<< "1 0 1\n"
<< "1 1 1\n"
<< "0 1 1\n"
<< "4 0 3 2 1\n"
<< "4 0 1 5 4\n"
<< "4 1 2 6 5\n"
<< "4 2 3 7 6\n"
<< "4 3 0 4 7\n"
<< "4 4 5 6 7\n";
ss >> P;
void set_box2(Polyhedron& P)
ss << "OFF\n"
<< "8 6 0\n"
<< "0.25 0.25 -0.25\n"
<< "0.75 0.25 -0.25\n"
<< "0.75 0.75 -0.25\n"
<< "0.25 0.75 -0.25\n"
<< "0.25 0.25 1.25\n"
<< "0.75 0.25 1.25\n"
<< "0.75 0.75 1.25\n"
<< "0.25 0.75 1.25\n"
<< "4 0 3 2 1\n"
<< "4 0 1 5 4\n"
<< "4 1 2 6 5\n"
<< "4 2 3 7 6\n"
<< "4 3 0 4 7\n"
<< "4 4 5 6 7\n";
ss >> P;
int main()
Polyhedron box1, box2;
set_box1(box1);
set_box2(box2);
std::ofstream out;
out.open("box1.off");
out << box1;
out.close();
out.open("box2.off");
out << box2;
out.close();
Nef_polyhedron nef1(box1);
Nef_polyhedron nef2(box2);
Nef_polyhedron nef_diff12 = nef1 - nef2;
Surface_mesh output;
CGAL::convert_nef_polyhedron_to_polygon_mesh(nef_diff12, output);
out.open("diff12.off");
out << output;
out.close();
- [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/07/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/14/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/15/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/15/2017
