cgal-discuss - Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
  • Date: Wed, 15 Nov 2017 15:49:17 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:yLdqYRN3sOqO3HZvqBIl6mtUPXoX/o7sNwtQ0KIMzox0K/nyrarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZFRz7cAZ0Pe/oAZX6jsKt1un09YeATR9PgW+mbbR4JQ62rE2Fus4ciJBiK70sxQbTv1NHfu1XwSVjIlfFzEW03du54JM2q3cYgPkm7cMVCag=
Dear Sebastien,
Following your advice, the code worked perfectly!
Thank you very much for your kind support!!
S Dobashi
