Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- Date: Wed, 15 Nov 2017 06:18:56 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:AQ//PRAXj75vTwN+5ILEUyQJP3N1i/DPJgcQr6AfoPdwSP3+rsbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHERr2MU95J//+B5XJp8WxzeG7vZPJMCtSgz/oer91JhytrQSZ4sURi4J5Kqcq1xTUuGZgdOFfxGcuLlWWyUWvrvys9YJupnwD88kq8NRNBP33
Dear Sebastien,
Thank you very much for your kind and prompt bug fix!
I fetched your PR, and
I confirmed that the desired results are successfully obtained
for boxes I used previously as an example (box1.off - box2.off).
Sorry, however, the error like bellow occurred for trc1.off - trc2.off.
(difference between two truncated right cones)
Code and data files I used are attached to this message.
I want to the Boolean operation works fine for any typical shapes
such as box, cone, cylinder, wedge, tetrahedron, etc.
Perhaps, something is still wrong with the code?
Thanks,
S Dobashi
Her's the error
CGAL error: assertion violation!
Expression : ss_circle.has_on(sp)
File :
D:\opt\CGAL\cgal-PR\Nef_3\include\CGAL/Nef_3/polygon_mesh_to_nef_3.h
Line : 263
Explanation:
Refer to the bug-reporting instructions at
http://www.cgal.org/bug_report.html
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Surface_mesh.h>
#include <CGAL/Nef_polyhedron_3.h>
//#include <CGAL/boost/graph/convert_nef_polyhedron_to_polygon_mesh.h>
#include <fstream>
typedef CGAL::Exact_predicates_exact_constructions_kernel Exact_kernel;
typedef CGAL::Polyhedron_3<Exact_kernel> Polyhedron;
typedef CGAL::Surface_mesh<Exact_kernel::Point_3> Surface_mesh;
typedef CGAL::Nef_polyhedron_3<Exact_kernel> Nef_polyhedron;
int main(int argc, char** argv)
Polyhedron P1;
auto fin1 = std::ifstream(argv[1]);
fin1 >> P1;
fin1.close();
Polyhedron P2;
auto fin2 = std::ifstream(argv[2]);
fin2 >> P2;
fin2.close();
Nef_polyhedron nef1(P1);
Nef_polyhedron nef2(P2);
Nef_polyhedron nef_diff12 = nef1 - nef2;
//Surface_mesh output;
//CGAL::convert_nef_polyhedron_to_polygon_mesh(nef_diff12, output);
Polyhedron output;
nef_diff12.convert_to_polyhedron(output);
auto fout = std::ofstream("diff12.off");
fout << output;
fout.close();
box1.off <http://cgal-discuss.949826.n4.nabble.com/file/t375861/box1.off>
box2.off <http://cgal-discuss.949826.n4.nabble.com/file/t375861/box2.off>
trc1.off <http://cgal-discuss.949826.n4.nabble.com/file/t375861/trc1.off>
trc2.off <http://cgal-discuss.949826.n4.nabble.com/file/t375861/trc2.off>
- [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/07/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/14/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/15/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/15/2017
