Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3
- Date: Wed, 15 Nov 2017 07:13:02 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23:zks7HRSMHMwSczus3M0tkz+hidpsv+yvbD5Q0YIujvd0So/mwa67YR2N2/xhgRfzUJnB7Loc0qyN7PCmBDRIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnZBUin4YAF6L+CwFo/JhNmszMiz/YfSakNGnmmTe7R3eQ66qg/YrckXyd9uLaw40RvIuWZHZv5L7WxtLFOX2R3745Hjr9ZY7y1Mtqd5pIZ7WqLgcvFgQA==
Dear Sebastien,
At least for the example trc1.off - trc2.off, the assertions bellow seem to
fail:
Nef_3\include\CGAL\Nef_3\polygon_mesh_to_nef_3.h
line 263, 264
CGAL_assertion(ss_circle.has_on(sp));
CGAL_assertion(ss_circle.has_on(sv_prev->point()));
line 294, 295, 296
CGAL_assertion(ss_plane.has_on(sv_prev->point()));
CGAL_assertion(ss_circle.has_on(sp_0));
Nef_S2\include\CGAL\Nef_S2\Sphere_direction.h
line 105
CGAL_assertion(d1.has_on(p) && d2.has_on(p) && d3.has_on(p));
Nef_S2\include\CGAL\Nef_S2\Sphere_segment.h
line 61
CGAL_assertion(c.has_on(p1)&&c.has_on(p2));
In Release mode, the subtraction works fine for the truncated right cone
example.
thanks,
S Dobashi
- [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/07/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/14/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, sdobashi, 11/15/2017
- Re: [cgal-discuss] Rectangular tube is capped on the surface when converting Nef_Polyhedron_3 to Polyhedron_3, Sebastien Loriot (GeometryFactory), 11/15/2017
