- To:
- Subject: Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements
- Date: Tue, 24 Apr 2018 14:07:35 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::FT Number_type;
typedef CGAL::Arr_segment_traits_2<Kernel> Traits;
typedef Traits::Point_2 Point;
typedef Traits::X_monotone_curve_2 Segment;
typedef CGAL::Arrangement_2<Traits> Arrangement;
typedef Arrangement::Vertex_handle Vertex_handle;
typedef Arrangement::Halfedge_handle Halfedge_handle;
typedef Arrangement::Face_handle Face_handle;
typedef Arrangement::Vertex_const_handle Vertex_const_handle;
typedef Arrangement::Halfedge_const_handle Halfedge_const_handle;
typedef CGAL::Arr_consolidated_curve_data_traits_2<Traits, int>
Data_traits;
typedef Data_traits::Curve_2 Numbered_segment;
typedef CGAL::Arrangement_2<Data_traits> Numbered_arr;
Numbered_arr arr;
insert(arr, Numbered_segment(Segment(Point(1.6831200000000E+02,-1.3992000000000E+01), Point( 1.2253100000000E+02, -2.0889000000000E+01)), 6));
insert(arr, Numbered_segment(Segment(Point(1.6490200000000E+02, 1.0314000000000E+01), Point( 1.0342400000000E+02, 4.2850000000000E+00)), 11));
insert(arr, Numbered_segment(Segment(Point(1.7217000000000E+02,-3.2611000000000E+01), Point( 9.9756000000000E+01, -4.3728000000000E+01)), 16));
insert(arr, Numbered_segment(Segment(Point(1.4197300000000E+02, 5.4490000000000E+00), Point( 1.4887000000000E+02, -4.0331000000000E+01)), 51));
std::stringstream ss;
Numbered_arr::Vertex_const_iterator vit;
for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit)
std::map<int, int> Frequency;
Numbered_arr::Halfedge_around_vertex_const_circulator eit, first;
eit = first = vit->incident_halfedges();
do
++Frequency[eit->curve().data().front()];
} while (++eit != first);
ss << "@ ( " << vit->point() << ")" <<std::endl;
for(auto & itr : Frequency)
ss<<itr.first<<" apprears "<<itr.second<<"\n";
Numbered_arr::Edge_const_iterator eit;
std::vector<int> Pid;
for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)
Data_traits::Data_container::const_iterator it;
if(eit->curve().data().size()> 1)
Pid.clear();
Pid.reserve(eit->curve().data().size());
for (it = eit->curve().data().begin(); it != eit->curve().data().end(); ++it)
Pid.push_back(*it);
ss<<"Overlap detected : ";
for(auto & itr : Pid)
ss<<itr<<" ";
ss<<"\n";
ss << arr.number_of_edges() << " edges:" << std::endl;
ss << "[" << eit->curve() << "]" << std::endl;
On Tue, Apr 24, 2018 at 12:33 PM, Efi Fogel <> wrote:
Please provide a test case that reproduces the problem.____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/On 24 April 2018 at 17:32, Dinesh Shetty <> wrote:When I switched to CGAL 4.12-beta2 from CGAL-4.4, I get following exception thrownException: CGAL ERROR: precondition violation!Expr: (m_traits.compare_y_at_x_2_object()(p, cv) == EQUAL) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGERFile: D:\PE\PE_Software\3rdParty\CGAL\CGAL-4.12-beta2\include\CGAL/Arr_segment_traits_2.hLine: 714Any help appreciated..On stackExchange
- [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Florian Prud'homme, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/26/2018
