- To:
- Subject: Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements
- Date: Wed, 25 Apr 2018 11:30:09 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
This could have never worked.
You are using inexact construction.typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On 24 April 2018 at 22:07, Dinesh Shetty <> wrote:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;typedef Kernel::FT Number_type;typedef CGAL::Arr_segment_traits_2<Kernel> Traits;typedef Traits::Point_2 Point;typedef Traits::X_monotone_curve_2 Segment;typedef CGAL::Arrangement_2<Traits> Arrangement;typedef Arrangement::Vertex_handle Vertex_handle;typedef Arrangement::Halfedge_handle Halfedge_handle;typedef Arrangement::Face_handle Face_handle;typedef Arrangement::Vertex_const_handle Vertex_const_handle;typedef Arrangement::Halfedge_const_handle Halfedge_const_handle;typedef CGAL::Arr_consolidated_curve_data_traits_2<Traits, int>Data_traits;typedef Data_traits::Curve_2 Numbered_segment;typedef CGAL::Arrangement_2<Data_traits> Numbered_arr;Numbered_arr arr;insert(arr, Numbered_segment(Segment(Point(1.6831200000000E+02,-1.3992000000000E+01), Point( 1.2253100000000E+02, -2.0889000000000E+01)), 6));insert(arr, Numbered_segment(Segment(Point(1.6490200000000E+02, 1.0314000000000E+01), Point( 1.0342400000000E+02, 4.2850000000000E+00)), 11));insert(arr, Numbered_segment(Segment(Point(1.7217000000000E+02,-3.2611000000000E+01), Point( 9.9756000000000E+01, -4.3728000000000E+01)), 16));insert(arr, Numbered_segment(Segment(Point(1.4197300000000E+02, 5.4490000000000E+00), Point( 1.4887000000000E+02, -4.0331000000000E+01)), 51));std::stringstream ss;Numbered_arr::Vertex_const_iterator vit;for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit){std::map<int, int> Frequency;Numbered_arr::Halfedge_around_vertex_const_circulator eit, first;eit = first = vit->incident_halfedges();do{++Frequency[eit->curve().data().front()];} while (++eit != first);ss << "@ ( " << vit->point() << ")" <<std::endl;for(auto & itr : Frequency){ss<<itr.first<<" apprears "<<itr.second<<"\n";}}Numbered_arr::Edge_const_iterator eit;std::vector<int> Pid;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit){Data_traits::Data_container::const_iterator it;if(eit->curve().data().size()> 1){Pid.clear();Pid.reserve(eit->curve().data().size());for (it = eit->curve().data().begin(); it != eit->curve().data().end(); ++it){Pid.push_back(*it);}ss<<"Overlap detected : ";for(auto & itr : Pid)ss<<itr<<" ";ss<<"\n";}}ss << arr.number_of_edges() << " edges:" << std::endl;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)ss << "[" << eit->curve() << "]" << std::endl;On Tue, Apr 24, 2018 at 12:33 PM, Efi Fogel <> wrote:Please provide a test case that reproduces the problem.____ _ ____ _
_/On 24 April 2018 at 17:32, Dinesh Shetty <> wrote:When I switched to CGAL 4.12-beta2 from CGAL-4.4, I get following exception thrownException: CGAL ERROR: precondition violation!Expr: (m_traits.compare_y_at_x_2_object()(p, cv) == EQUAL) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGERFile: D:\PE\PE_Software\3rdParty\CGAL\CGAL-4.12-beta2\include\CGAL/Arr_segment_traits_2.hLine: 714Any help appreciated..On stackExchange
- [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Florian Prud'homme, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/26/2018
