- To:
- Subject: Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements
- Date: Wed, 25 Apr 2018 15:49:30 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Well my version with 4.4 works
Change the first line to:This could have never worked.You are using inexact construction.
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/On 24 April 2018 at 22:07, Dinesh Shetty <> wrote:typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;typedef Kernel::FT Number_type;typedef CGAL::Arr_segment_traits_2<Kernel> Traits;typedef Traits::Point_2 Point;typedef Traits::X_monotone_curve_2 Segment;typedef CGAL::Arrangement_2<Traits> Arrangement;typedef Arrangement::Vertex_handle Vertex_handle;typedef Arrangement::Halfedge_handle Halfedge_handle;typedef Arrangement::Face_handle Face_handle;typedef Arrangement::Vertex_const_handle Vertex_const_handle;typedef Arrangement::Halfedge_const_handle Halfedge_const_handle;typedef CGAL::Arr_consolidated_curve_data_traits_2<Traits, int>Data_traits;typedef Data_traits::Curve_2 Numbered_segment;typedef CGAL::Arrangement_2<Data_traits> Numbered_arr;Numbered_arr arr;insert(arr, Numbered_segment(Segment(Point(1.6831200000000E+02,-1.3992000000000E+01), Point( 1.2253100000000E+02, -2.0889000000000E+01)), 6));insert(arr, Numbered_segment(Segment(Point(1.6490200000000E+02, 1.0314000000000E+01), Point( 1.0342400000000E+02, 4.2850000000000E+00)), 11));insert(arr, Numbered_segment(Segment(Point(1.7217000000000E+02,-3.2611000000000E+01), Point( 9.9756000000000E+01, -4.3728000000000E+01)), 16));insert(arr, Numbered_segment(Segment(Point(1.4197300000000E+02, 5.4490000000000E+00), Point( 1.4887000000000E+02, -4.0331000000000E+01)), 51));std::stringstream ss;Numbered_arr::Vertex_const_iterator vit;for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit){std::map<int, int> Frequency;Numbered_arr::Halfedge_around_vertex_const_circulator eit, first;eit = first = vit->incident_halfedges();do{++Frequency[eit->curve().data().front()];} while (++eit != first);ss << "@ ( " << vit->point() << ")" <<std::endl;for(auto & itr : Frequency){ss<<itr.first<<" apprears "<<itr.second<<"\n";}}Numbered_arr::Edge_const_iterator eit;std::vector<int> Pid;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit){Data_traits::Data_container::const_iterator it;if(eit->curve().data().size()> 1){Pid.clear();Pid.reserve(eit->curve().data().size());for (it = eit->curve().data().begin(); it != eit->curve().data().end(); ++it){Pid.push_back(*it);}ss<<"Overlap detected : ";for(auto & itr : Pid)ss<<itr<<" ";ss<<"\n";}}ss << arr.number_of_edges() << " edges:" << std::endl;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)ss << "[" << eit->curve() << "]" << std::endl;On Tue, Apr 24, 2018 at 12:33 PM, Efi Fogel <> wrote:Please provide a test case that reproduces the problem.____ _ ____ _
_/On 24 April 2018 at 17:32, Dinesh Shetty <> wrote:When I switched to CGAL 4.12-beta2 from CGAL-4.4, I get following exception thrownException: CGAL ERROR: precondition violation!Expr: (m_traits.compare_y_at_x_2_object()(p, cv) == EQUAL) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGERFile: D:\PE\PE_Software\3rdParty\CGAL\CGAL-4.12-beta2\include\CGAL/Arr_segment_traits_2.hLine: 714Any help appreciated..On stackExchange
- [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Florian Prud'homme, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/26/2018
