- To:
- Subject: Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements
- Date: Wed, 25 Apr 2018 16:07:27 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
It worked for many years for all the problems I have tried, but I switch to 4.12 now it breaks
When you use inexact construction, your program may work on some instances and may fail on other.We do not guarantee anything.____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/On 25 April 2018 at 18:49, Dinesh Shetty <> wrote:Well my version with 4.4 worksChange the first line to:This could have never worked.You are using inexact construction.
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;____ _ ____ _
_/On 24 April 2018 at 22:07, Dinesh Shetty <> wrote:typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;typedef Kernel::FT Number_type;typedef CGAL::Arr_segment_traits_2<Kernel> Traits;typedef Traits::Point_2 Point;typedef Traits::X_monotone_curve_2 Segment;typedef CGAL::Arrangement_2<Traits> Arrangement;typedef Arrangement::Vertex_handle Vertex_handle;typedef Arrangement::Halfedge_handle Halfedge_handle;typedef Arrangement::Face_handle Face_handle;typedef Arrangement::Vertex_const_handle Vertex_const_handle;typedef Arrangement::Halfedge_const_handle Halfedge_const_handle;typedef CGAL::Arr_consolidated_curve_data_traits_2<Traits, int>Data_traits;typedef Data_traits::Curve_2 Numbered_segment;typedef CGAL::Arrangement_2<Data_traits> Numbered_arr;Numbered_arr arr;insert(arr, Numbered_segment(Segment(Point(1.6831200000000E+02,-1.3992000000000E+01), Point( 1.2253100000000E+02, -2.0889000000000E+01)), 6));insert(arr, Numbered_segment(Segment(Point(1.6490200000000E+02, 1.0314000000000E+01), Point( 1.0342400000000E+02, 4.2850000000000E+00)), 11));insert(arr, Numbered_segment(Segment(Point(1.7217000000000E+02,-3.2611000000000E+01), Point( 9.9756000000000E+01, -4.3728000000000E+01)), 16));insert(arr, Numbered_segment(Segment(Point(1.4197300000000E+02, 5.4490000000000E+00), Point( 1.4887000000000E+02, -4.0331000000000E+01)), 51));std::stringstream ss;Numbered_arr::Vertex_const_iterator vit;for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit){std::map<int, int> Frequency;Numbered_arr::Halfedge_around_vertex_const_circulator eit, first;eit = first = vit->incident_halfedges();do{++Frequency[eit->curve().data().front()];} while (++eit != first);ss << "@ ( " << vit->point() << ")" <<std::endl;for(auto & itr : Frequency){ss<<itr.first<<" apprears "<<itr.second<<"\n";}}Numbered_arr::Edge_const_iterator eit;std::vector<int> Pid;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit){Data_traits::Data_container::const_iterator it;if(eit->curve().data().size()> 1){Pid.clear();Pid.reserve(eit->curve().data().size());for (it = eit->curve().data().begin(); it != eit->curve().data().end(); ++it){Pid.push_back(*it);}ss<<"Overlap detected : ";for(auto & itr : Pid)ss<<itr<<" ";ss<<"\n";}}ss << arr.number_of_edges() << " edges:" << std::endl;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)ss << "[" << eit->curve() << "]" << std::endl;On Tue, Apr 24, 2018 at 12:33 PM, Efi Fogel <> wrote:Please provide a test case that reproduces the problem.____ _ ____ _
_/On 24 April 2018 at 17:32, Dinesh Shetty <> wrote:When I switched to CGAL 4.12-beta2 from CGAL-4.4, I get following exception thrownException: CGAL ERROR: precondition violation!Expr: (m_traits.compare_y_at_x_2_object()(p, cv) == EQUAL) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGERFile: D:\PE\PE_Software\3rdParty\CGAL\CGAL-4.12-beta2\include\CGAL/Arr_segment_traits_2.hLine: 714Any help appreciated..On stackExchange
- [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/24/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Florian Prud'homme, 04/25/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 04/26/2018
