cgal-discuss - [cgal-discuss] CGAL_assertion: identifier not found
  • To:
  • Subject: [cgal-discuss] CGAL_assertion: identifier not found
  • Date: Fri, 15 Jun 2018 03:30:22 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23:VlvfjhcJ2Kqbm2Z3QUfpSq84lGMj4u6mDksu8pMizoh2WeGdxcu6Yx7h7PlgxGXEQZ/co6odzbaO7ua4ASQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTahYb5+Ngm6oRnMvcQKnIVuLbo8xAHUqXVSYeRWwm1oJVOXnxni48q74YBu/SdNtf8/7sBMSar1cbg2QrxeFzQmLns65Nb3uhnZTAuA/WUTX2MLmRdVGQfF7RX6XpDssivms+d2xSeXMdHqQb0yRD+v6bpgRh31hycdLzM3/mHZhNJzgqxGrx2uuxNxzpXIYIyXKPZyYr/Rcc8ESWdHQ81fVzZBAoS5b4YXFOoOI/xYr4b8p1sJsBCzAhesC/nzxT9JgH/20qM60+M7EQHBxwEgENcOv27VrNXxLqsdTee1zKzRwDjFcvhY1zD96I3SfRAgp/GBRbRwftDKxkY0EwPKkE+cppDiPzOQ0OkGrmuV7/J4WO6yimMrtRt9riavy8oikIXFm4wYx17e+Sh73oo4I8CzRlRhbt6+CpRQsjmXN4toTcMmRGFloCA6x7IctZ69ZicF048oxxrBZPCdb4eI5RfjWP6QITd+mn1lZKqyiwuz/ES+0OHwSMm53VhQoiZYnNTBuGoB2h7N5sSfT/ty5Eah2TKB1wDJ7eFEJFg5lbTBJJE9w74wkJUTsUrEHi/sn0X7l6CWdkA+9eip7+TreKnpppiZN4NskAHxLrwumtCjAeQ/KgUBQ2eb9v641LH64EL5Qa5KgeErkqnCq5DXPt8bp668Aw9NyIkv8Re/DzG80NQZh3YLNlxFeAjUx7TublrBKfS9AfakiEm3ix9qwerHN/vvGMbjNH/GxazsZ7l87AYI1gM4zNZQ6ZVODZkOJfvyXgn6s9mOXUxxCBC93+uyUIY17YgZQ2/aWvbIYpOXikeB46cUG8fJYYYUvDjnLP18vqzhiHY4nRkWeqz7hsJLOkD9JexvJgCiWVSpms0ISD5YsQ83Teisg1qHA2YKOiSCGpkk7zR+M7qISIfOQof03e6HgGG9F5dcYm0AAVeJQy7l
Adding to my code this line:
bool solved =
CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
I get the error:
"CGAL_Assertion: identifier not found"
And after check it i found the line 489 of property_map.h
CGAL_assertion(pm.set_ptr!=NULL);
Some definition is missing. What wrong?
