- To:
- Subject: Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp
- Date: Tue, 19 Jun 2018 17:31:49 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
If you have this error message it means that you are trying to access
the property of an element that is outside of the range of simplices.
Are you sure you did not modify the example in the manual?
I did not modified the example, but i found out it runs on
Ubuntu 16.04 Linux.
I also get a internal error in gdb while getting this exception,
maybe a error in gcc/g++ in fedora 28 ?
so long
MUFTI
- [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/20/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, j. scheurich, 06/21/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/21/2018
