- To:
- Subject: Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp
- Date: Thu, 21 Jun 2018 12:23:22 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:dQJf3BeTvYz3Wx2efsjE1E/flGMj4u6mDksu8pMizoh2WeGdxcu+YR7h7PlgxGXEQZ/co6odzbaO7ua4ASQp2tWoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6nK94iQPFRrhKAF7Ovr6GpLIj8Swyuu+54Dfbx9HiTahYb5+Ngm6oRnMvcQKnIVuLbo8xAHUqXVSYeRWwm1oJVOXnxni48q74YBu/SdNtf8/7sBMSar1cbg2QrxeFzQmLns65Nb3uhnZTAuA/WUTX2MLmRdVGQfF7RX6XpDssivms+d2xSeXMdHqQb0yRD+v6bpgRh31hycdLzM37mHZhNFzgqxVrh2uqABwzYHPbYGJN/dzZL/Rcc8USGdDWMtaSixPApm7b4sKF+cNM+RYo5PgrFsVsRS+BRejBP71yj9JmnD23aM22PkmHAHDwQwgEc4OsHXJoNnoL6oTX/66w7LSwTrecfxbwDHw45XGfBAmpPGDR7NwcczJxEkgCQzFiVCQppL5PzOP1uUNvXKU4PZ8VeKokW4mqxt9rSSoxscpjITCm4Ebykjc+Cln3Yo5O8e0RFBlbdOmCpdcqiOXO5FrTs8/W21kpTg2x7kctZKmcyUHxo4rywPDZ/CbaYSE/xDuWeiXLDxlnnxqYqi/iAy38UW4yu3zSM200FFSoypAldnMq2wN2wbd68eZUfRx5Fqu1iiX2wDS7OFLP1w0mLLFJ5I83LI8jIQfvVrBEyPshUn7jrWaelg59uSw7uToeLTmppuSN49ujQH+N7wjmsmiAeQ2LggOXnWX9fmn2bzt40L2W69GgeAonaXBqpDVOdwbprKlAw9Syoss9xm/AC2i0NgBgHYHLUlFdw6aj4jyIFHDO+v4DPe6g1S0ijhn3fHGPrv7ApXMNHfPirnhfawuo3JbnQE8xNQa65NPAawaO9ryXFXwvZrWFEwXKQuxlqzlTp1m3YMTRHiOCa/TePfXrFGU57t2C/aBbskZtWCueLAe+/fygCphyhcmdq6z0M5PMSHqLrFdO0ycJEHUrJIEGGYOsBA5Sby4l1CIFzJeNS/rA/AMowojAYfjNr/tA5i3iezTwyqxWJFbNDgfVwK8VEzwfoDBYM8iLSKfJsg4yW4BUqW9DZAs31eiuV2ixg==
> > There must be something fishy here. See for example our test results
> > here:
> > https://cgal.geometryfactory.com/CGAL/testsuite/results-4.13-I-34.shtml
> > You'll see that the line Surface_mesh_Examples where sm_circulators.cpp
> > is tested can be compiled and ran successfully on all our test platforms
> > (that includes some of yours).
> In the CGAL test results, all the test platforms named Fedora<something> (but
> not Fedora-rawhide) are using the last public version of Fedora: Fedora 28.
Are you really sure ? Fedora 28 was realeased on 1. Mai 2018, maybe
the test is not in sync with the fedora release...
so long
MUFTI
- [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/19/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Sebastien Loriot (GeometryFactory), 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, J. Scheurich, 06/20/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/20/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, j. scheurich, 06/21/2018
- Re: [cgal-discuss] exception in Surface_mesh_2sm_circulators_8cpp, Laurent Rineau (CGAL/GeometryFactory), 06/21/2018
